DSS 5.9 Axle Hub Question
http://www.driveshaftshop.com/main_cat1.php
Pro have 28 splines, search on their site. I'm sure the info is there somewhere.
The amount of splines are only ONE part of the axle hub mating combo. The splines have different back cuts and depths among other things that could be different even if they have the same amount of "teeth". The back part of the hub could also be different where the axle meets the hub just as the older dss stuff is compared to the newere dss stuff. The axles will physically go in and tighten but will bind up due to a different radius on the back side.
So in the end, run the hubs meant for the axles and you will be ok.
make sure you get the right hubs for the generation axle you have. Like I said, some of the dss stuff will "fit" but will bind up once the axle nut is tightened if the correct hub isnt used.
i dont mean to jump in but i have a question having to do with dss..
well theyre spool work with stock axles... cuz i dont have the money to buy the 5.9 yet.
just picked up a gsr and dont feel like installing the tranny in without an lsd or spool then taking the tranny out again... any input is appreciated... thanks
^Why don't you call them?
THE DRIVE SHAFT SHOP
1531 SOUTH MAIN ST
SALISBURY NC 28144
9:00-4:30 Monday Thru Friday
//Eastern Standard Time
800-564-2244 Orders
704-633-2380 Tech
704-633-2385 Fax
1531 SOUTH MAIN ST
SALISBURY NC 28144
800-564-2244 Orders
704-633-2380 Tech
704-633-2385 Fax
swarley
Transmission & Drivetrain
Jan 28, 2011 06:56 AM
