CRX vs EF hatch
Old Apr 28, 2009 | 10:47 AM
88 EF Hatch's Avatar
Default CRX vs EF hatch
88-89 CRX headlight the same or different as 88-89 EF hatchback headlight? Are they interchangeable? are the brackets the same of different?
Old Apr 28, 2009 | 10:58 AM
slowassBubble's Avatar
Default Re: CRX vs EF hatch
no they are not interchangeable and also they change from 88-89 and 90-91
Old Apr 28, 2009 | 11:04 AM
yea i was aware of the year that they change. just making sure
Old Apr 28, 2009 | 11:07 AM
RUCHO01's Avatar
I think they are same...
Old Apr 28, 2009 | 07:38 PM
uberEFtuner's Avatar
Any easy way to see if parts are interchangeable is to look up aftermarket parts on a good website. For example look up projector head lights for 88-89crx and compare the picture to 88-89 civic. But sorry they are not interchangeable.
Old Apr 28, 2009 | 07:45 PM
crx_si-r's Avatar
88-89 crx head ligths are identical as 90-91. as far as the brackets and corner lights, those are different.
Old Apr 28, 2009 | 07:56 PM
boostedmonkey's Avatar
I think they are, too. That's what my buddy at work, at Honda tells me, and he's been working there for 10-11 years. At the same dealership.
Old Apr 28, 2009 | 08:01 PM
ha...tch's Avatar
All 88-91 crx/civic headlights are the same
Old Apr 28, 2009 | 08:39 PM
garageEF's Avatar
Truth.
Old Apr 28, 2009 | 08:56 PM
so wth? everyone is saying different things. Who honestly knows, because I want to buy 3dr hatch projectors so that I can use clean plastic cover on my oem housing headlights but ebay just sells "88-89 civic crx projector halo headlights"
Old Apr 28, 2009 | 08:58 PM
Canadian_EF's Avatar
All 88-91 headlights are the same, with minor changes
some have a moisture trap, to filter out moisture.
but, all the brackets are different.
even the sedan ones will fit, as long as you change the brackets.
i should know... my crx has a hatchback headlight. gonna change it out for a sedan one right away though.
Old Apr 28, 2009 | 09:33 PM
xaine's Avatar
i have also used several different head lights in my 90 crx si and my 90 civic si
headlights all fit if you change the brackets
side markers come in different ways
Old Apr 29, 2009 | 12:18 AM
hushypushy's Avatar
This is a key point. It's not the headlight that you have to worry about, it's the bracket. I swapped 90/91 headlights into an 89 that had eBay projectors, but I had to take out the 90/91 OEM lights and reuse the 88/89 eBay bracket to make it fit.
Old Apr 29, 2009 | 06:22 AM
Deetz's Avatar
Crazy Honda Guy
The headlights can be interchanged no problem, i've done it many times!
The brackets only differ from the side marker mounting position, so you can either swap the brackets (easy), or just get the matching style of side markers to go along with what ever gen headlight brackets you have. 88-89 or 90-91
Hope this helps clear up everything
Old Apr 29, 2009 | 07:51 AM
kojack_0's Avatar
yup. all 88-91 usdm civic and crx [including 4dr] headlights are interchangeable.
you just need to change the brackets it mounts on:
if you want your corner lights to have a 'one-screw-mount' use a 90-91 headlight bracket.
if you want your corner lights to have a 'dual-screw-mount' use the 88-89 headlight bracket.
other than that the headlight itself are all the same.
Old Apr 29, 2009 | 08:04 AM
mitsubishiv5's Avatar
id change the bracket. btw did you know your going to spend 100+ for some ebay headlights just to get the lenses?
Old Apr 29, 2009 | 08:52 AM
Because they have gay projectors for 70 bucks and free shipping...but ok I hope this is right
Old Apr 29, 2009 | 09:01 AM
hushypushy's Avatar
hmm I just saw this. Why not just use plastic polish on your OEM lights? If you're gonna take the lights apart anyway, why not refurbish the OEM ones? I bet you could even find some OEM or OEM replica headlights for the same price as the ugly projector ones.
Furthermore, I'm not sure you're aware, but the projector covers will be different than the OEM ones. Not by a whole lot, and I'm not saying that it won't fit, but it will be different.
Old Apr 29, 2009 | 11:32 AM
DONTSLEEP_'s Avatar
Originally Posted by deetz
the headlights can be interchanged no problem, i've done it many times!
hope this helps clear up everything
+1
Old Apr 29, 2009 | 12:00 PM
elldirt's Avatar
New User
How about going to pep boys and get a headlight polishing kit for $15? Then swap the hi beam and low beam wiring in the plugs. After you re-aim the headlights you can drive around with really bright lights and everybody will think you spent a bunch of money.
Old Apr 29, 2009 | 01:33 PM
billboard's Avatar
88-89 crx/hatch/sedan/wagon headlights all the same
90-91 crx/hatch/sedan/wagon headlights all the same
Corner lights all differ from eachother...
VTi_b0i
17
Apr 10, 2013 04:27 AM
91civicsikid
12
Jul 12, 2009 01:45 AM
sloweh3
Dec 24, 2003 04:10 PM
goodwinesi
Nov 25, 2003 05:08 PM
Trevor
Oct 22, 2002 04:15 PM
