EF Oem headlight housing with plastic cover
I'm pretty sure its been done, but does any body have any pics of using oem usdm ef hatch or rex headlight housing and getting rid of glass cover and using plastic cover instead? and What to pros and cons are?
I think you would to start off with an aftermarket "conversion" headlight. Generally, they are used to convert older sealed beam headlamps into the modern replaceable bulb lamps, and some come with clear lenses. I'd bet you can find one in the correct size, if you search hard enough.
Example:
Example:
but i have a composite headlight. My hatch is an 88 not the old school models lol. so I was gonna use aftermarket projector plastic cover and put on my oem housing but i just wanted to make sure that the aftermarket projectors fit on my oem housing. here are the pics<br>
<br>
<br>
You can't just use a clear lens. The reflector in the OEM headlights was not designed as a "free-form" reflector. Without the prism pattern on the lens, the light will not be dispersed out where it needs to go with the stock reflectors.
The high beams of those projector headlights have free-form reflectors (whether they are designed properly is another story). They are (hopefully) designed to put the light where it needs to go without the need for the prismatic pattern on the lens.
Then what about the eg headlights? They come stock with fluttered prism headlight lens, but the jdm replicas have that clear glass lens. And they still work fine
If you put clear lenses on lamps designed to have fluted lenses, the light output will be awful I suspect.
MotorMouth93
Mar 27, 2016 04:45 AM
88 EF Hatch
41
Apr 30, 2009 01:02 PM
