Help please!! rear suspension question
Old Apr 28, 2009 | 09:35 AM
eg_6@1904's Avatar
Default Help please!! rear suspension question
I am trying to install coilovers on my 92 hatch and have run into a problem. The head of the bolt on the right rear shock which holds it to the lower contol arm is extremely rusted and worn and i am unable to take it out. My question is, if i remove the whole lower control arm with shock to get the springs in, will it extremely throw off my alignment. the reason i ask is because i did once to my 98 prelude and there was an eccentric nut which aligned the suspension. will i have any alignment issues if i remove the whole rear control arm and shock together?
Old Apr 28, 2009 | 09:40 AM
tambourineman999's Avatar
Default Re: Help please!! rear suspension question
Yes you will. its your only choice and you should have you car re aligned anyways . It is best to replace all your bolts and arms if you have the cash and time otherwise cut out the bolt and replace a small piece of metal over and drill it out....
bizak
May 30, 2011 07:33 AM
s13hero
Aug 18, 2009 11:23 PM
92-LS-Civic
Suspension & Brakes
12
Apr 1, 2005 12:53 PM
ChaseIntegra
May 19, 2003 12:58 PM
Civic1992DX
Mar 23, 2003 06:10 PM
