Is my clutch slipping??
Old Apr 28, 2009 | 08:38 AM
efjones9's Avatar
Default Is my clutch slipping??
it has been like this ever since i tightend my clutch cable. in first its perfect i could burnout all day lol. but from 1st to 2nd it seems like it takes a long time for the clutch to engage? like it jumps from 2k to 3k really slow. and some time when i try to speed up in 3rd the engine revs but doesnt go anywhere? i think my clutch is almost out but dont wana do all that work to change it if its just because i tightened it too much. any suggestions or diagnosis for me ??
Old Apr 28, 2009 | 09:55 AM
lu0724's Avatar
Default Re: Is my clutch slipping??
I had the same problem on my sentra... I just replaced the clutch.. I didnt know what else to do..
Old Apr 28, 2009 | 10:41 AM
KaiPerrigo's Avatar
New User
yeah its your clutch when your on flat road and you speed after going into gear does the rpm gauge go up but not the speedometer then speedometer moves up while you have rpm steady at high rpm range? then yes your clutch is going out mainly your pressure plate you make clutch to tight and it warped pressure plate....sorry best fix it soon so your not going on the freeway and clutch final goes out out and your reving up to 4000 rpm and car just sitting there.......seen it happen right on the on rap to freeway, it was sad, does it also take you forever to slow down when you just down shift and not use brakes on a flat road get up to about comfy 3rd or 4ft gear then down shift and see if car slows down or takes forever don't give it gas or brake rpm should jump up and car should slow down if rpm is down at like 1000 rpm in 2 nd or 3rd and your still flying and engine does rev up then yes clutch is going out
Old Apr 28, 2009 | 12:02 PM
efjones9's Avatar
when i down shift it feels normal
Old Apr 28, 2009 | 10:24 PM
SquirtleSquadEf9's Avatar
if u floor it and rev it up to high rpms and u shift to 2nd and the rpms stay up but ur not going any were ur clutch is slipping. just change it. take like 4 to 8 hours wit a jack and piece of wood
Old Apr 29, 2009 | 10:22 PM
efjones9's Avatar
Old Apr 29, 2009 | 10:23 PM
efjones9's Avatar
thanx ima jus change it
ic89
10
Oct 15, 2006 03:14 PM
Flux
Nov 26, 2003 11:25 PM
gsrXredline
Dec 11, 2002 11:36 AM
LOwrestling2001
May 26, 2002 03:28 AM
STOLEN - ITR 98-0652
Nov 26, 2001 12:18 PM
