cant find bilstein sports for 92-95 civic coupe?
anyone know a part number? or what i have to do, to make them fit from another application?
i also thought about revalveing the hd's to work, but that would cost more.
thanks for any input
be5 6408 will work in the front.
the HD rear shocks are the same size as what a sport shock would be anyway (46 mm piston and removable spring perch)
In both cases, the valving will not be optimal anyway, so I would either revalve, or don't worry about it.
i did more searching and found that i can use the 96-00 set all around except in the back i will need diferent lca bushings.
is that true?
is that true?
GTEC913
26
Mar 13, 2009 11:03 AM
c.u.one
Apr 12, 2004 09:17 PM
