b18c gsr skunk2 header vs toda
hy guys
here is the setup
b18c1 block
81.50 wiseco pistons 11,7comp +-
p72 head port & polished
omni valves
supertech valvsprings
blox spec C camshafts
blox cam gears
skunk2 intake mani
maxbored tbody 65mm
2,5 b pipe
spoon n1 exhaust
stock air box wht k&n filter
p30 ecu
toda header vs skunk2 header
what is your choice?
here is the setup
b18c1 block
omni valves
blox cam gears
skunk2 intake mani
maxbored tbody 65mm
2,5 b pipe
spoon n1 exhaust
p30 ecu
Crap, I was hoping for some real data and information, like a dyno showing the two. Not an opinion poll. Do some home work, search and read up. I have had a bad day sorry.
hy guys
here is the setup
b18c1 block
omni valves
blox cam gears
skunk2 intake mani
maxbored tbody 65mm
2,5 b pipe
spoon n1 exhaust
p30 ecu
here is the setup
b18c1 block
omni valves
blox cam gears
skunk2 intake mani
maxbored tbody 65mm
2,5 b pipe
spoon n1 exhaust
p30 ecu
Different headers have different reasons. some for peak power for drag racing, others have midrange power for circuit racing. "better" depends upon what the car is being used for, despite your wonderful parts list.
p30 tuned with crome
smsp send-me a header for portugal(europe)?and the price off iss header??
sorry for my bad english
i put toda c spec cams in my itr. along with their itb (individual throttle body) setup. they have tremendous performance especially at higher rpms. this may be do to the throttle bodies also. but with my exhaust system, intake, and cams, along with a few other mods my car put out 203whp, i can show you the dyno sheet, but as far as which is better (skunk or toda) and performs better i cant really tell you.
the decision breaker for me was that toda made itb's, which i as looking for, and decided to just put in all toda products. ill try and scan my dyno sheet and post it up then.
btw skunk and toda have pritty much the same products, depending on which cams your looking at, they perform almost the same. my itr is street and im using toda products, and i have no problems, been driving it for 2yrs now.
https://honda-tech.com/forums/showth...light=vteckidd hope it helps
crazydominicanman
22
Dec 18, 2011 11:27 AM
