ac turns on and off....
Old Apr 27, 2009 | 07:44 PM
pkolaboy's Avatar
Default ac turns on and off....
ok so i have a 92 prelude si... When my ac is on... it will turn on and off... and so on..... has anybody ever had this problem?
Old Apr 27, 2009 | 09:14 PM
TheJGB3's Avatar
Default Re: ac turns on and off....
What do you mean? Does the compressor keep cycling on/off? (low refridgerant charge) Does the blower keep going/stopping? (motor or resistor)
Old Apr 27, 2009 | 10:41 PM
Inextricabledrvr's Avatar
Is it possible that you have a wire that is loose somewhere? I had an issue with a intermittent a/c and I had a wire that was spliced by accident. I just twisted it back together and no more problems ever since then. good luck
Old Apr 28, 2009 | 10:45 AM
pkolaboy's Avatar
The ac blower is still on but it turns hot then cold... but i did get the system recharged before this though...
Old Apr 28, 2009 | 10:58 AM
mattsnooz's Avatar
Your green light remains on though correct?
Old Apr 28, 2009 | 12:08 PM
pkolaboy's Avatar
uhhh... i think it might of been blinking on and off... its like when i hit a bump or something the ac just kicks off...
Old Apr 28, 2009 | 04:51 PM
teambk8's Avatar
i had the same problem, it is either the wire in the back of the ac unit came loose or the unit itself is bad... there is a guy on here that has some used ones for sale and/or can fix yours. If the light goes on and off then that is def your problem
Old Apr 28, 2009 | 05:53 PM
pkolaboy's Avatar
Thanks everybody... i think imma just buy a new climate control.....
Dragonsfire
Sep 26, 2018 07:40 PM
redbug2
Jul 3, 2014 01:14 PM
momchenr
Honda Civic (2001 - 2005)
Jul 29, 2011 03:43 PM
asmallsol
Sep 26, 2006 01:36 PM
