Who is Rockin the Pin Stripe?
Old Apr 27, 2009 | 07:02 PM
Civilized81's Avatar
Default Who is Rockin the Pin Stripe?
Hey there, My integra has a pin stripe and it feels embossed. I wanted to remove it but when I looked closer I saw that it was paint. Is this on any of your integras? Was this just done while being repainted?? I dont see the pin stripe on other integras so I assume it is not stock. I know it is lame that it is painted on and I cant get it off! What do you guys think of the pin stripe ordeal?
Old Apr 29, 2009 | 09:41 AM
r.wright's Avatar
Default Re: Who is Rockin the Pin Stripe?
im not sure if it will work for your striping since it may or may not be older than my car but on my 01 acura mdx suv the previous owners had pin striping painted on and i used 'fine cut' rubbing compound to remove it then wax to clean it all up. i tried the 'easy off' method before this but that was just a huge mess.
Old Apr 29, 2009 | 12:33 PM
sde780's Avatar
I used a razor blade
It didn't work too well
Old Apr 29, 2009 | 11:09 PM
NW Classic Honda's Avatar
A heat gun and a plastic scraper.
Old Apr 30, 2009 | 12:08 AM
LobeSex's Avatar
lmao ouch...im guessing that didnt turn out good?
Old Apr 30, 2009 | 11:11 AM
hookedonponics's Avatar
I thought using a 3m rubber wheel takes off pin stripes.
Old Apr 30, 2009 | 11:31 AM
sde780's Avatar
3m wheels works great.
i accidentally took off chunks of paint with the razorblade lol. it wasnt even a razor blade, just an exacto knife i happened to have.
im repainting the car anyways so i didnt care, but you shouldnt try it
Old Apr 30, 2009 | 03:18 PM
shocker911's Avatar
becarful if you use this not to burn the paint...but a heat gun and some goo gone and a filler spreader
bigislandc2
Paint and Body
May 1, 2012 08:06 PM
zanderclause
May 20, 2007 07:57 AM
iwhichisme
Jun 20, 2004 04:00 PM
GSblueRacing
Mar 27, 2003 09:02 PM
Tammy_EP3
Mar 18, 2003 09:09 PM
