Suspension & Brakes Theory, alignment, spring rates....
soft vs stiff
Old Apr 27, 2009 | 06:38 PM
Duc_du's Avatar
Default soft vs stiff
I am going to get my new tokico illumina and eibach pro kit install this weekend. The thing is i can adjust the softness and stiffness of the illumina but i believe the eibach spring rate are pretty soft so i was wondering will it make a difference if i set the shock stiffness all the way?
Old Apr 27, 2009 | 10:55 PM
COEHR's Avatar
Default Re: soft vs stiff
well let me just say....pro kit sucks should've gotten the sportlines but either way it would be "ok" lil body roll still
Old Apr 28, 2009 | 07:23 AM
Duc_du's Avatar
how does pro kit suck? anyway i was asking about the adjustment not whether this combo is good or not. Believe me this spring is only temporary, going to go GC in couple of years. thanks for feed back anyway
Old Apr 28, 2009 | 01:48 PM
TunerN00b's Avatar
Yes, it will make a huge difference, especially with how the Illuminas adjust both bump and rebound together when you turn the ****.
Start on full soft. Drive the car, and get used to it. Turn up the fronts some, and drive some more. Repeat until it feels "too stiff" or "harsh". Its now over damped, so back off 1 adjustment and leave alone. Repeat process for rear.
Old Apr 28, 2009 | 01:58 PM
Duc_du's Avatar
thanks a lot this is more than i ask for! cool i will do that this week and check it out. what damper is good for daily driving?
Old Apr 28, 2009 | 02:25 PM
TunerN00b's Avatar
For use with the pro-kit springs?
Illuminas, AGX, Koni Sport (Yellow), Bilstein HD or Sport.
Any would be fine. Each would be slightly different.
I run Koni Sports. For pure street use, I'd probably opt for Illuminas.
Tootsie7944
Honda CR-V & Element
12
May 13, 2021 08:06 PM
FERIOGUY
12
Jan 28, 2015 03:12 PM
2camsaam
Aug 5, 2014 04:48 AM
BB1R
Nov 15, 2006 02:48 PM
zc911
May 8, 2003 04:28 PM
