new brakes...squeak terrible
Old Apr 27, 2009 | 02:33 PM
Tegraracer90's Avatar
Default new brakes...squeak terrible
i just put new front pads on my integra...they came with that thin piece of metal that goes around the back side of the pad between the pad and caliper..i put that on...but now about 3 weeks into driving the car they squeak when i push the brake pedal..
and yes i did check and there is plenty of pad left so it isnt the wear sensor
can i use that red stuff that u buy at the auto parts store that goes between the pad and caliper to fix this?...or is that only for older vehicles?
Old Apr 27, 2009 | 02:56 PM
MD426's Avatar
Default Re: new brakes...squeak terrible
It's not the brake against the caliper, it's the brake against the rotor that makes the squeaking.
Old Apr 27, 2009 | 03:01 PM
90_EX_Civic's Avatar
actually it's a combination of the two. the squeaking is caused by vibration, a certain frequency. that's why you here a squeak in stead of grinding. putting the red stuff in between the pads and the caliper will help to muffle that vibration. breaks up that frequency.
this is lamens terms, there is a technical way of saying it, but this is all i can remember of the top of my head.
Old Apr 27, 2009 | 03:23 PM
Tarmac Junkie's Avatar
Did you turn the rotors when you put new pads in?
Old Apr 27, 2009 | 04:02 PM
TunerN00b's Avatar
Good question.
Regardless of the answer though, were the new pads bedded correctly? Most people skip that step, and then wonder why they have brake noise... Its even more important if old rotors were used that were not turned / deglazed.
Old Apr 27, 2009 | 04:13 PM
MD426's Avatar
Originally Posted by TunerN00b
Good question.
I have brake noise and my rotors are as shiny as can be (I assume thats what you mean by glazed), but I have awesome braking. People who drive my car say that they grab really well also, no problems in rain. Odd.
Old Apr 28, 2009 | 09:44 AM
no i didnt have the rotors turned yet...i havent had the time...i will eventually get to it
Old Apr 28, 2009 | 10:35 PM
jdm_bones's Avatar
You have to turn the old rotors or replace with new ones, when you install new pads...because the uneven surface of the old rotor will ruin your new pad, and the glazed rotor against a new pad can cause bad braking power at low speeds in your front brakes because your metering valve is doing the light brakeing control at that given time, this can result in hitting the car in front of you at a stop light. As far as the nosie goes, that is just vibration that you are hearing due to not using the silcone based anti-squeak, and not turning your rotors...This means that there are areas that aren't makeing contact...which = vibration. I bet they shake when trying to stop at high speeds...Take them to someone who knows what they are doing, before you cause an accident....Due to your ignorance!
mickey513
Nov 16, 2018 03:56 PM
dc2b20v
Suspension & Brakes
Jan 18, 2010 07:41 PM
Import_spoon
Oct 23, 2006 03:25 PM
Arsenal
Jan 5, 2006 09:21 AM
94gsr_vtc
Mar 30, 2005 06:34 PM
