91 honda accord lx door skins.
first you need to take the doors off and grind the outside edge with a grinder. then take a air chissel or putty knife with a hammer and seperate the layer of skin from the shell of the door. then you need to clean the new skins outer edge that will rest on the shell to bare metal. You also need to clean the shell where the skin rests to bare metal then use panel bond or door skin adhesive on both peices. lay the skin on the shell then begin to roll over the edges with a hammer and dolly. If you are good you can do this and not have any mud work to do on the door if your not your gonna need to staighten the door after you roll the skin. then test fit the door on the car make sure you have good gaps. If your gaps are good take the door back off and weld the places you should have spot welds. probably on a honda under where the belt mdlg is.
If you have no idea how to do one i wouldnt reccommend trying it.
