Can you run 2 ohm speakers off a 4 ohm amp ?
Old Apr 27, 2009 | 07:09 AM
redDAinteg's Avatar
Default Can you run 2 ohm speakers off a 4 ohm amp ?
If I have a 4 channel amp running 4 ohms for the door speakers, can I run 2 ohm (Infinity Kappa 62.9i) speakers off of it no problem ?
Old Apr 27, 2009 | 07:13 AM
twentyhurtz's Avatar
Default Re: Can you run 2 ohm speakers off a 4 ohm amp ?
MOST 4ch amps are 2ohm stereo stable, i have heard of some 4ohm stereo stable amps, but no in the last 15 years... and those amps were hardcore SQ amps.. think they were mcintosh, maybe wrong... anyways to your question, if you have 6x9's that have 2ohm vc's, and the amp is 2ohm stereo stable, then yes, it is ok, if you have 1 speaker per channel.
Old Apr 27, 2009 | 07:18 AM
dj-t's Avatar
I have it running straight off my alpine 9815 for two years now and its fine. I've also installed it with some flea market 4ch amps for people and to this day its still plays fine and nothing wrong with there amps.
Look at the manual for your amp and see if it is capable of it.
You can also check out Infinity's website they also have a answer there for your question.
Old Apr 27, 2009 | 11:22 AM
mrdeadman's Avatar
They let me pick
What is the make/model of the amp?
Old Apr 27, 2009 | 05:45 PM
fcm's Avatar
fcm
Old Fart
As mentioned, most 4ch amps are stable to 2 ohms, [in 4ch mode].
As asked, make and model of amp and we can tell for sure. 94
Old Apr 28, 2009 | 11:38 AM
redDAinteg's Avatar
rockford fosgate p400-4
Old Apr 28, 2009 | 11:44 AM
ok thats a 2ohm stereo stable amplifier, i can automatically tell you that without looking it up.
Old Apr 28, 2009 | 11:48 AM
so you can safely comfortably run 1 infinity speaker per channels, as spec'd above..
Old Apr 28, 2009 | 04:22 PM
fcm's Avatar
fcm
Old Fart
Rockford Fosgate 4ch amps are stable down to 2 ohms in the 4ch mode and down to 4 ohms in bridged 2ch mode.
So as long as you leave amp in 4ch mode you will be fine with two or four 2 ohm speakers, or a set of 4 ohm and a set of 2 ohm speakers.94
Old Apr 28, 2009 | 06:00 PM
Jabrony325's Avatar
Yes I agree with these guys. You are safe. I used to install a butt load of Fosgate stuff from Best Buy and you have nothing to worry about.
Old Apr 28, 2009 | 06:38 PM
i miss my power 250....
GetawayInMoscow
Audio / Security / Video
Apr 13, 2009 02:41 PM
94 IntegraLS
Dec 29, 2007 06:15 AM
gsr civic dx
Apr 18, 2005 11:20 AM
Drum_Guru
Oct 8, 2003 08:22 PM
mstewar
Sep 28, 2003 08:28 PM
