no start code 15....All ready searched all over
Old Apr 27, 2009 | 06:58 AM
northemt88's Avatar
Default no start code 15....All ready searched all over
good morning a have 89 hf with a obd0 LST,got the code 15. i went threw 3 good dizzys still no start,checked all the wires all good(the ones i was able to track).everything else works there is fuel, but no spark....Also when i turn the key over to prime the motor the tach jumps up and i can feel the motor move.i think its the starter thats moving.also swaped out my ecu and still nothing.PLEASE HELP
Old Apr 27, 2009 | 11:23 AM
northemt88's Avatar
Default Re: no start code 15....All ready searched all over
bump
Old Apr 27, 2009 | 11:28 AM
93formula's Avatar
does it crank freely? can you have some one crank the car and look thru the oil cap to see if your cam is moving.
Old Apr 27, 2009 | 02:07 PM
redflaredcrx90's Avatar
do ya get spark if notmake sure that your harness isnt cut and is grounded its self out
Old Apr 27, 2009 | 02:59 PM
jlicrx's Avatar
are you using the HF engine harness? - not ever going to work if you aren't, without modifying the harness
Old Apr 27, 2009 | 04:10 PM
northemt88's Avatar
its the hf one.have used if for six months no problem,out of no were it hapened
Old Apr 27, 2009 | 04:11 PM
northemt88's Avatar
it cranks freely.the cam spins also
Old Apr 27, 2009 | 04:40 PM
KWayRacing's Avatar
See if you have voltage12v on the large Black/yellow stripe wire in the 2 pin connector at the distributor. If not that is the source of your problem. Also pay attention to the 2 white wires at the distributor connector on the engine wire harness. Give each wire a very gentle tug Maybe one of those wires are broken right at the connector. good luck
Old Apr 27, 2009 | 09:31 PM
northemt88's Avatar
thanks man.i will check
Old May 3, 2009 | 10:45 AM
KWayRacing's Avatar
well?
Gaspari
Engine Management and Tuning
Jul 5, 2010 09:48 PM
ef-hatchcrap
Feb 16, 2010 07:45 AM
My_EFsedan
11
Nov 3, 2008 01:48 PM
vtecn8ive
Mar 16, 2006 09:16 AM
Sampsonite987
Apr 6, 2004 07:27 AM
