Jdm obd0 B16 wire harness
Hi, I just bought a Jdm obd0 b16 complete swap and planning to install it in my crx 89 si. My question is why can't i use the Jdm obd0 b16 wire harness. On both sides the clips are exactly the same. The reason I'm asking is because i sold my stock motor with the original wire harness. What are my alternative?
-Thanks Fellas
-Thanks Fellas
Just go to the junkyard and get one out of any multi point or if your not lucky enough just go with the dual point and add all the neccesary to make it work as the extra injectors knock sensor vtec,solenoid and extra 02 sensor is not that hard, and just like he said is always easier go with your stock harnes otherwise you gonna end up extending about 30 ft of wire LOL..
Both sides plug in perfectly?
That's awesome!
Become a wiring mad-man and rewire your ECU pins!
I would do it... yeah, it's probably not worth the hassle at all, but it would keep me busy and out of trouble for a long long very long long time.
That's awesome!
Snail Tuning
Oct 27, 2004 09:29 AM
hughesl
Aug 7, 2003 05:11 PM
