4spd to 5 spd swap quick question.
Old Apr 26, 2009 | 10:35 PM
4gen5thtime's Avatar
Default 4spd to 5 spd swap quick question.
I'm going to be helping a friend swap his std for a dx trans soon. He has a new clutch, new mounts and all that. But will his old axles work from the 4 speed. I searched and found very lil info. I've heard of having to swap axles or hubs but really do you have to? He's not going to be putting any uber power in to it its just a dd. Both trans are from a 1990.
Thanks
Old Apr 26, 2009 | 10:44 PM
88_acED6's Avatar
Default Re: 4spd to 5 spd swap quick question.
i just put the bigger hubbed axles and hubs from a si into my 4 speed
Old Apr 26, 2009 | 10:46 PM
garageEF's Avatar
you should have no problems using the same axles.
Old Apr 26, 2009 | 10:49 PM
So then we shouldnt need to change anything but pop out old trans, do the clutch stuff and pop in the new one fill her up and call it good? Where at in oregon you? I'm down in florence and used to live in gp/medford area.
Old Apr 26, 2009 | 10:52 PM
garageEF's Avatar
correct.
im about half way between portland and salem. just made a trip out to newport today though.
Old Apr 26, 2009 | 11:18 PM
Haha sweet. I love oregon.
Old Apr 27, 2009 | 06:40 AM
Cnile1's Avatar
The dx axles should fit. I have a four speed and I just replaced my axles with dx axles.
Old Apr 27, 2009 | 03:34 PM
ryanevansoh's Avatar
well the splines on the std model are smaller going into the hubs. i dont know about the tranny side though
Old Apr 27, 2009 | 03:57 PM
4drEF's Avatar
Keyboard Humorist
Use the stock HF axles with the DX trany
-OR-
swap out hubs for DX.
Either way will work fine.
Old Apr 27, 2009 | 06:41 PM
rallypoint_1's Avatar
I had a 4sp and swapped to a 5sp. Used the same axels. You should have no problems.
Old Apr 27, 2009 | 06:58 PM
Cnile1's Avatar
Exactly... They should slide right into the tranny.
Old Apr 27, 2009 | 09:03 PM
Sweet I thought so I just wanted to double check before going over there tomorrow and being stuck on the axles.
BIGef
Feb 18, 2012 03:48 AM
soodominican
11
Jan 26, 2010 09:00 AM
trevorjohn88ef
Jan 6, 2010 09:23 PM
Red_ED8
Oct 13, 2005 02:16 PM
youngwon22
Oct 14, 2003 07:47 PM
