b18a head on b16 block???
Old Apr 26, 2009 | 06:51 PM
GsrHatcher's Avatar
Default b18a head on b16 block???
trying to find out if an b18a1 head will work on b16 block?????
Old Apr 26, 2009 | 07:11 PM
vangaurd's Avatar
Default Re: b18a head on b16 block???
I Highly Highly Highly doubt that... as b16 block is a vtec block and the b18a head is a non vtec head... I doubt it so much im gonna go with NO on this one.
Old Apr 26, 2009 | 07:48 PM
GsrHatcher's Avatar
ok so what about ls/vtec swaps? non vtec block with vtec head right?
Old Apr 26, 2009 | 07:52 PM
AMLS4dr200whp's Avatar
the oil passage are different which is why it wont work
Old Apr 26, 2009 | 09:57 PM
mario_pic's Avatar
its posible lol its just like makeing a lsvtec motor except u plug the oil feed on the block just like u plug it on the head lol i did it made 156hp on dyno head was ported and had s2 cams 2 layer head gasket also p30 pistons lol kida funny tho lol sounds odd tho lol not like eney motor i have heard b4 lol run it as a shop car lol good for boost motor will be boosted in a few mounths lol depends on whats laying around the shop lol other then that its not bad saves on gas tho works find motor has been runing for 2 years now lol
Old Apr 26, 2009 | 11:46 PM
wascly's Avatar
Which timing belt did you use mario?
Please no more lol in your posts...
Old Apr 27, 2009 | 04:13 AM
kyden's Avatar
i assume a b16 along with the water pump. ls would be too long.
Old Apr 27, 2009 | 10:48 AM
mario_pic's Avatar
correct lol match the water pump with the timeing belt thats the key
lol o we sprayed the motor with some left over spray from a our track car lol that little bugger moves lmao
motors like a dohc zc but with lots more torq and rpm lol more relaiable and cheaper to buy and find parts for lol so its a better swap compaired to a zc swap and u can even over bore the block to get even more torq
Old Apr 27, 2009 | 10:58 AM
DB2-R81's Avatar
25 Year Member
Not even Babel Fish could sort this out!
Old Apr 28, 2009 | 08:00 AM
killerB16A's Avatar
lmao!
Old Apr 28, 2009 | 08:10 AM
H9Omega's Avatar
omg, stfu with the lol, are you really loling? weird motor setup though, i've personally never seen/heard of anything like it.
Old Aug 31, 2024 | 08:44 PM
Felonious m's Avatar
[Hey I'm doing the b18a1 to b16 head thing I'm just wondering what to do about the oil cooler on the b16 block do I just block the passages or can it be removed or ?
Old Sep 2, 2024 | 09:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Why do you want to remove the oil cooler ?
BlakeJ53
Dec 28, 2006 01:34 PM
harlesjohn
Nov 14, 2005 07:35 PM
harlesjohn
Nov 14, 2005 03:18 PM
JDMLEROY
May 24, 2005 09:45 AM
b16si
Feb 8, 2004 11:48 AM
