Sacramento, CA-FS:89 civic turbo gsr rhd civic sir
im tired of projects so buy mine lol
i have an 89 civic sir (ef9) that has been imported from japan. i built the car from a bare shell and it is about 75% complete to my standards. most everything was replaced with sir parts from japan. unfortunatly that is where it has costs the most and been the biggest headache but all of the hard parts are done. im asking 10kobo for everything or 8K just for the sir.
CIVIC SIR:
suspension/brakes:
omni power drag fullbody coilovers
steel braided brake lines
skunk2 rear lower tie bar
arp extended wheel studs all around
new rear brake pads
turned rear rotors
integra brake booster
integra mastercylinder
custom front traction bar w/adjustable preload front mount
15" bbs dish mesh wheels (dont know much about what model but looks nice)
engine:
magnetic drainplugs
new timing belt
new timing belt tentioner
arp headstuds
new cometic head gasket
fluidyne 1/2 size radiator
slim fan
aem cam gears
rsr turbo edition cat-back exhaust
greddy axle-back exhaust
action clutch
7lbs flywheel
92 gsr transmission
new axles
97 gsr block with balanced and blueprinted p73 (usdm itr) pistons w/30k miles
99 gsr head w/ 60k miles
valve cover modified with 2 -10 an fittings for catch can
-10an t1 block fittings for catch can
type r throtttle body
custom tranny mount
custom shift linkage
comptech carbon fiber sparkplug cover
nology spark plug wires
interior:
2 6 point harnesses
2 simpson 5 point harnesses included
usdm front seats
usdm rear seats
rare civic map light
integra type r shift boot
non-srs jdm integra type r steering wheel (stock sir included)
everything else stock sir
110 km on chassis
body:
spoon mc covers
benen front tow hook
benen rear tow hook
new fuel tank
new fuel pump
rolled and flared front fenders
rolled front pinch welds (required if your going to put a camber kit in the front and be low)
most of the tar removed fender wells, undercarriage, floorboards
tucked power steering cooler
full wire tuck
converted to obd1 for hondata kept the peak and hold injectors though
turbo kit (yes it fits with ac,ps,and b series)
inline pro stainless steel manifold
tial 38mm wastegate
precision sc50 turbo
custom stainless steel intercooler piping
custom 5 bolt 2.5"-3" downpipe
hks intercooler
aeromotive fpr
str fuel rail
steelbraided fuel line for fpr
fitting for fpr
greddy profec b boost controller
greddy turbo timer
gm 3 bar map sensor
golden eagle vacume manifold
clamps/couplers ect
apexi filter
custom intake tube
oil sending unit
earls oil lines
-10an fitting for oil pan drain
compaq presario laptop stripped down to be used for tuning
autometer boost gauge
autometer oil pressure gauge
autometer water temp gauge
egt gauge
aem wideband w/gauge
arc bov
the registration has been started and i am in the process of getting the vehical approved by chp to be registered just need to find time. currently the turbo kit is not on because i am still missing a few things as you can see to make it a solid kit; such as fuel pump, injectors, hondata, dyno ect. so it is all motor for now. but it does run and drive fine, just needs an alignment. the things i am including are:
95 CIVIC 4 DOOR DX: (my current daily)
ac
ps
clean title
registered
passed smog
30+mpg
del sol seats
coilovers (not installed)
shortshifter
pioneer cd deck
pioneer speakers
clean inside and out
stock sohc
EXTRAS:
complete jdm h22 swap (everything except motor mounts)
dc header for h22
act clutch for h22
b16 longblock:
gsr head
custom gsxr1000 itbs
b18a bare block
sprint usdm front strut bar
jdm ef9 doors
complete sohc turbo kit:
braced and rewelded ebay turbo manifold
capped off external wastegate flange
adapter flange to fit t3-14b
14b turbo (no shaft play)
intercooler piping
rx7 intercooler w/custom bracket for eg civic (goes where the stock air box is located)
blitz bov
oil ines
-10 fitting for oil pan drain
1st gen safc
dsm 450cc injectors w/ resistor box
im sure there are alot more parts i just cant think of everything off the top of my head, as i said i want out of projects and i want a normal car lol. any interests feel free to contact me @ (916)289-6149 Please no low ballers, flakes, or dreamers
Thanks,
Jason
CIVIC SIR:
suspension/brakes:
new rear brake pads
turned rear rotors
engine:
magnetic drainplugs
new timing belt
arp headstuds
slim fan
aem cam gears
action clutch
7lbs flywheel
92 gsr transmission
new axles
custom tranny mount
interior:
2 6 point harnesses
usdm front seats
usdm rear seats
110 km on chassis
body:
spoon mc covers
benen rear tow hook
new fuel tank
new fuel pump
full wire tuck
tial 38mm wastegate
hks intercooler
aeromotive fpr
str fuel rail
fitting for fpr
greddy turbo timer
gm 3 bar map sensor
clamps/couplers ect
apexi filter
custom intake tube
oil sending unit
earls oil lines
egt gauge
arc bov
ac
ps
clean title
registered
passed smog
30+mpg
del sol seats
shortshifter
pioneer cd deck
pioneer speakers
stock sohc
EXTRAS:
dc header for h22
act clutch for h22
b16 longblock:
gsr head
b18a bare block
jdm ef9 doors
intercooler piping
blitz bov
oil ines
1st gen safc
Thanks,
Jason
Devil CRX
Oct 8, 2009 09:33 AM
Type V
Aug 26, 2005 12:33 PM
