P1457 - Control System Leak Detected
Old Apr 26, 2009 | 02:57 PM
Lithel's Avatar
Default P1457 - Control System Leak Detected
P1457 - Control System Leak Detected (control canister). That's what I've got. I've been doing some reading here on this site and found a couple of things that could be causing it:
- Bad/Loose gas cap (I replaced mine less than a year ago though)
- Failed vent or purge solenoid.
- Failed hose connection or hose.
The threads I read had some good info in them, but none of them had any recommended way of attacking this code. What should I check/do first to try to get rid of it? The easiest would be to get a new gas cap, but my current one is less then a year old, they "break" that fast? Anyway, as far as the purge solenoid and the hoses go, any cheap/quick way to check these out? I'm not very experienced with fixing these kinds of things, but like learning new things about my car.
Any suggestions?
Old Apr 26, 2009 | 03:04 PM
ekb16's Avatar
Default Re: P1457 - Control System Leak Detected
there is a troubleshootin procedure for it but it requires a hand pump vaccum and dmm...
Old Apr 26, 2009 | 04:26 PM
Lithel's Avatar
Okay, where would you get a hand pump vacuum and what's a dmm?
Old Apr 26, 2009 | 04:53 PM
ekb16's Avatar
harbor freight has those..a dmm is a digital multi meter
Old Jun 29, 2009 | 06:23 PM
ehulst's Avatar
Could be that your EVAP canister is full of water.....more common on the 98-02 Accords...
Old Jun 30, 2009 | 06:57 AM
Lithel's Avatar
It turned out that my battery has been dripping acid onto my evap canister, burning a hole straight through the top. Replaced it yesterday.
WideBodyFEELZ
Jun 24, 2009 04:08 PM
uhcord98
Oct 12, 2006 06:05 PM
SIMATIC
Nov 18, 2004 11:23 AM
Philbert
Jul 10, 2004 05:44 PM
