Piston to valve measurement, with headgasket or not?
Old Apr 26, 2009 | 11:46 AM
97CTR's Avatar
Default Piston to valve measurement, with headgasket or not?
I remember hearing that when checking the valve to piston clearance it is best done without a headgasket. You can get whatever thickness gasket that will put your setup within spec.
Is this a valid statement? What are the benefits of checking without using a hg?
Old Apr 26, 2009 | 12:12 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Piston to valve measurement, with headgasket or not?
You run a stock head gasket, measure the clearance and then decide if you need a thicker/thinner gasket.
Old Apr 26, 2009 | 01:56 PM
lohatch's Avatar
you could do it either way. if you do it without the gasket and you have say .050" clearance and you are going to run a .030" gasket then you will have .080" which would be sufficient with a steel rod.
the benefit of checking it without the gasket would be not tightening the head to the block and then taking it back off with your new gasket.
and i wouldnt base your HG thickness on piston to valve. set your quench at what you want and if your PtoV is too tight, i would flycut the piston.
Old Apr 26, 2009 | 09:53 PM
K20EF8's Avatar
Are you sure this is correct, shoudnt it be
clearance without gasket + (gasket thickness*cosA)
where A is the valve angle from the vertical (perpendicular to the block)
Old Apr 27, 2009 | 06:26 PM
97CTR's Avatar
Thanks for the reply and I understand all of that, I was just wondering if there was some "other" reason.
HiGhGuY
Jul 30, 2014 10:13 AM
LstCivic
Feb 16, 2008 10:19 PM
b16 matt
Jan 30, 2008 11:53 AM
getgot22
Mar 27, 2006 06:28 PM
bikeboy80
Nov 23, 2001 07:34 AM
