Pics of my 11.1 comp. LS Integra
Old Apr 26, 2009 | 10:56 AM
non-vtecpower's Avatar
Default Pics of my 11.1 comp. LS Integra
82mm rs machine usdm b18c5 pistons
Arp rod bolts and headstuds
Arizona race girdle,Gsr oil pickup,windage tray and oil pan.
Acl race bearings
Inline pro built head, port and polish,3 angle valve job, 20 thousands shaved
Crower dual valve springs, Ti retainers, Crower 403 cams
Skunk2 intake manifold
Aem fuel rail, BDL 360cc Injectors, B&M fpr
Crane 5 bolt adj. Cam gears
OBX header ported as much as could be. 2 1/2 inch exhaust to a dyno max. no cat
unorthodox underdrive pully
Catch can
obd 0 to obd1 conversion. Crome tuned
After I get a throttle body its going to the dyno. I think it should be in the 180hp,140tq range. I have about 2000 miles on it now. 260 psi on each cylinder.
Old Apr 26, 2009 | 11:09 AM
92b18c1's Avatar
Default Re: Pics of my 11.1 comp. LS Integra
not bad the ls looks clean
Old Apr 26, 2009 | 11:14 AM
SlammedDC2teg's Avatar
Very different. I like!
Old Apr 26, 2009 | 11:19 AM
brandonEM1's Avatar
Old Apr 26, 2009 | 11:38 AM
hai_tech's Avatar
clean
Old Apr 26, 2009 | 11:54 AM
JollyGreen's Avatar
Nice.
Old Apr 26, 2009 | 12:02 PM
ONE-CAM-EF's Avatar
yo dude ur missing a lobe in ur cams..lol..jp..nice build u have there..and the teggy is clean props..
Old Apr 26, 2009 | 12:21 PM
turnsignalandy's Avatar
is it non vtec?
Old Apr 26, 2009 | 02:00 PM
Thanks
Yes its non-vtec. 95 B18b1
Old Apr 26, 2009 | 05:04 PM
haha I just noticed oure screen name. thats a lot of power man it sick
Old Apr 26, 2009 | 05:11 PM
MenaceL.A.671's Avatar
simple!
Old Apr 26, 2009 | 05:22 PM
Originally Posted by MenaceL.A.671
simple!
Thats why I love them. This is my 7th LS motor.
Old Apr 26, 2009 | 05:31 PM
JDM_EJ8's Avatar
clean DA
Old Apr 26, 2009 | 05:43 PM
what gsr's Avatar
pretty cool.. i like that its a da
Old Apr 26, 2009 | 09:14 PM
91redteg's Avatar
sick i had that same head setup except with a stock portand with a stock block it made 147 and 121
Old Apr 26, 2009 | 09:40 PM
bankhead83's Avatar
looking good, do you have anymore plans for it?
Old Apr 26, 2009 | 10:04 PM
EJ_ALLMOTA's Avatar
Originally Posted by non-vtecpower
After I get a throttle body its going to the dyno. I think it should be in the 190hp,145tq range. I have about 2000 miles on it now. 260 psi on each cylinder.
your guestimates are too high.. Expect to make 170whp +/- 5 if you are lucky..
I have a very similar setup in my EJ1
- stock ports
- 403 Cams
- Blox Intake manifold w/ Hondata intake manifold gasket
- Blox 68mm throttle body
- supertech valvetrain
- ferrera flat faced valves
- shot peened LS rods with B16 piston STD bore
- megan racing 4-2-1 header
- full 2.5in Greddy EVO exhaust
- My compression is around 11.3
My engine build makes 158whp and 122tq tuned with Chrome..
Graph: - red line is my current setup
- green one is my old setup when i had an RMF narrow header tuned with Uberdata back in 2005 when the motor was initally built..
Old Apr 27, 2009 | 11:24 AM
Needs some minor body work and a paint job. A better tranny with LSD. Better suspension, 404 cams...I could keep going. I have plans on building a higher compression bigger bore bottom end.. I want to break 200hp with a LS.. Next summer...
Old Apr 27, 2009 | 11:25 AM
jdm*LS*'s Avatar
Old Apr 27, 2009 | 11:28 AM
- stock ports
- 403 Cams
I will post the Dyno results when I get them... Sometime nextweek its going. I have a good tuner so Im hoping to break 180hp 140tq to the wheels... We will see.
Old Apr 27, 2009 | 10:17 PM
sintype's Avatar
Old Apr 27, 2009 | 11:37 PM
aeenox's Avatar
clean ls
Old Apr 28, 2009 | 12:12 AM
Scotty Dosent Know's Avatar
I like LS motors too, im LST right now. In for dyno results!
Old Apr 28, 2009 | 11:50 AM
Originally Posted by sintype
Originally Posted by aeenox
clean ls
Thanks
Old Apr 28, 2009 | 07:23 PM
Dumped DB2's Avatar
nice set up but your not gonna be anywhere near 180whp
