1990 CRX Si. getting no power at all.
Old Apr 26, 2009 | 06:40 AM
VTECengaged's Avatar
Default 1990 CRX Si. getting no power at all.
Hey guys. Maybe you could solve or help me troubleshoot my problem. I have a bone stock crx si, and i just replaced the head on it. When I went to turn it over for the first time, I put the keys in the ignition (i had power), I cranked the car for a couple seconds, and it didn't start up. At this point in time the ground was not connected up because I had forgotten to do so. Sparks then came from the positive battery terminal and I lost all power. I began by checking all of the fuses and cannot see and visual damage to any of them. Has anyone ever seen this problem? Thanks in advance.
Old Apr 26, 2009 | 08:53 AM
redflaredcrx90's Avatar
Default Re: 1990 CRX Si. getting no power at all.
check ground at battery check fuse un hood in the fuse box also check the main realy near the hood release
Old Apr 26, 2009 | 01:25 PM
bump
Old Apr 26, 2009 | 01:52 PM
Black4thgenEF's Avatar
Originally Posted by VTECengaged
bump
So did you check anything or do you just not like the first response or are you waiting for something easier? (There isn't much)
Here, I'll reiterate:
Check the main underhood fuse.
Check the ground battery connection.
What ground did you forget to connect?
KcAccord
Feb 28, 2015 06:03 AM
mikeycivic
Audio / Security / Video
Apr 13, 2010 10:57 AM
mar778c
Mar 1, 2008 05:49 AM
civickiller
Nov 21, 2005 12:48 AM
ILOVEGIRLS
Feb 23, 2004 03:30 PM
