i am about to do a tune up i have a few questions:
Old Apr 25, 2009 | 10:34 PM
949's Avatar
949
Default i am about to do a tune up i have a few questions:
its on a acura integra stock gsr 2001 4 door manual.
i plan on doing:
oil change,
spark plugs,
tranny fluid,
valve adjustment,
and the master cylinder for the clutch is leaking so ill need to replace that (not sure why that is leaking)
- does anyone have a diy instruction on the vavle adjustment on the this car?
- what is the valve measurement for the exhaust and intake i need to set it too?
- what is the order for valve adjustment?
- is there a recall or something on the clutch?
- is there anything else that needs to be done?
edit:
added to list
new dizzy
spark plug wires
o2 sensor
fuel filter
air filter
Old Apr 25, 2009 | 10:38 PM
sp00ledbseries's Avatar
Default Re: i am about to do a tune up i have a few questions:
cap,rotor,wires,o2. Search for valve lash specs you should find it fairly easy
Old Apr 26, 2009 | 07:13 AM
949's Avatar
949
thanks.
added your input.
anyone with the lash info?
plus anymore input.
Old Apr 26, 2009 | 07:47 AM
949's Avatar
949
any hoses should i replace at this point too?
i think ill need a new pcv valve but which one do i ask for when i go to kragen?
Old Apr 26, 2009 | 08:31 AM
sixfourkiller's Avatar
i plan on doing:
oil change,
spark plugs,
tranny fluid,
valve adjustment,
edit:
added to list
new dizzy
spark plug wires
o2 sensor
what is the valve measurement for the exhaust and intake i need to set it too.
well i know for the LS is for the intake side .003-005 and exhausted side 005-008
but i remember seeing for a gsr is a lil bigger i think its 004-006 and exhaust. 007-010
Old Apr 26, 2009 | 10:31 AM
kronikSLOW's Avatar
do not i repeat do not buy a pcv valve. save the 2 bucks clean it out with carb cleaner and wala its brand new again. i have never heard of a pcv valve actually needing replacing unless some ricer tried to put it in with a hammer or something.
Old Apr 26, 2009 | 06:39 PM
949's Avatar
949
i really dont mind spending a couple of dollars on a new pcv valve. that is one of the cheapest replacement parts i have seen. the can of brake cleaner is more then the pcv valve.
still cant find a definitive answer on the lash settings for this car.
Old Apr 27, 2009 | 12:02 PM
VTEC_Viking's Avatar
One of the first things you should buy if you plan to do work on your car is a Haynes or chiltons manual. All the specs will be in their. Usually the manuals are a little generalized because they include multiple model types but very helpful. Also find a down loadable service manual online they are everywhere probably one on this site for your generation car.
Old Apr 27, 2009 | 01:07 PM
wunfstgsr's Avatar
Loved
Community Favorite
are you seriouse!! just buy a new one its not that much and the pcv valve is one of the most important parts you can replace, will help with oil consumption and blowby. heres a sight to help you.
http://www.c-speedracing.com/howto/v...alveadjust.php
Old Apr 27, 2009 | 01:31 PM
JDMInteg96's Avatar
get a helms manual to do the valve adjustment.. the honda service manual.. it is readily available in pdf version online
Old Apr 27, 2009 | 02:33 PM
matt da jdm junkie's Avatar
whats the mileage and i can look up on Acura/Honda's Interactive network what should be done for the mileage
Old Apr 27, 2009 | 02:53 PM
rebar71's Avatar
http://www.team-integra.net/sections...?ArticleID=485
Google is your friend...
Old Apr 27, 2009 | 03:06 PM
spd2fst4u's Avatar
New User
Originally Posted by rebar71
yahoo is better though...
Old Apr 28, 2009 | 06:51 AM
949's Avatar
949
thanks for the link.
thanks too.
i would prefer the actual service manual but i dont know what they actually look like. does it actually say haynes.
online is going to just be more of a hastle because ill end up needing to pring it out anyways. so pdf is no good for me.
Old Apr 28, 2009 | 09:09 AM
rebar71's Avatar
We aren't allowed to post the link here for a download of the factory "integra service manual" - but as I said earlier, google is your friend...
Old Apr 28, 2009 | 10:06 AM
Be sure that you have the required tools before starting:
. Lock nut wrench
. Slot head screwdriver
. 10mm, 16mm, 19mm socket and rachet
. 6" extention
. Set of angled feeler gauges (0.006" and 0.007")
Factory spec for the B18C1/5 and B16A is:
Intake: 0.006"-0.007"
Exhaust: 0.007"-0.008"
Factory spec for the B18B and B20B/Z is:
Intake: 0.003"-0.005"
Exhaust: 0.006"-0.008"
Old May 1, 2009 | 07:06 AM
949's Avatar
949
so anything else i should replace?
also does anyone else have the leaky clutch m.c.?
what should i replace or fix?
are there multiple parts i need to buy besides the m.c.?
Old May 1, 2009 | 07:51 AM
ahcapone's Avatar
Fuel filter, air filter
Old May 3, 2009 | 06:41 AM
949's Avatar
949
thanks, i just added your recommendations.
Blindeye_03
11
Mar 10, 2010 03:29 AM
tr3-2001SE
Nov 28, 2005 09:48 PM
Fugazi
Oct 4, 2002 07:36 PM
Spade
Sep 20, 2001 08:18 AM
