Fuel Pump Bracket
Hey everyone so I have been working on my 88 crx si for a while now working out issue upon issue. I originally bought the car from a junk yard that was being pieced out and have been trying my hardest to bring this thing back from the dead. I can honestly say that I am pretty close but I keep running into problems that would put the devil's Z to shame...
alright so its an 88 but the car hasnt moved since 97...thus why there are tons of problems as well. I was replacing my fuel pump the other night and just my luck the devils crx decided to just fall the hell apart. Here for your viewing pleasure...my hell...
ok so as u can see from my wonderful diagram
-Pink-positive wire that goes from the top through the bracket (where it is sealed off and now broken) then it goes to the positive side of the actual pump itself
green- stupid shitty bolt which started this whole mess...i hate that bolt (it was stripped thus as the fuel tank came down thus did the fuel pipe and then a pinch became broke...
red- rubber fuel hose
blue- metal fuel line from top of bracket to rubber hose (fuel return line)
SOOOO i went to honda today...part is no longer manufactured or sold...yayyy...woopieeee...
so im wondering if i can modify my broken one.
does anyone know of where I can get a replacement return line for this? SS or whatever.
Also if I was to replace the positive wire what can i use to reseal it?
will any other fuel pump bracket fit?
On a side note i saw that on the integra bracket the return fuel line is rubber up to about 2 inches to the mount...might then therefore work on the rex by just swapping out the hose with a rubber one and then crimping and sealing the ends
