>>HELP with RSX-S ABS AND SRS LIGHT<<
On my '02 rsx-s, my ABS and SRS light just came on. its been on for about 2 weeks hoping it would turn off but its still on. im thinkin it may be a fuse? should i go get it diagnosed at the dealership? any suggestions? thanks alot!
I would go get it scanned. Most smaller shops won't have the proper computer to diagnose what's causing your issue. As long as that light is on generally your airbags will be faulty.
also make not to point out human error but the air bag system is also connected to your seats if you removed your seats for any reason and open the swich this can also be the cause of your light just adding my 2 cents
i had the SRS problem too, you got a 150,000 mile warranty on that dude you should get it checked out at the dealership or so thats what i did, turned out i needed to change my passenger seats airbag sensor, they did it and then they reset the SRS unit and there it is bro till now my light has not came on, about your abs i dont know what to tell you though
Blaze45
Mar 12, 2013 02:59 PM
