92 DA RS with B17 Swap, Correct Radiator Hoses??
Ok, I swapped my RS Chassis with a complete GSR Liftout and I've ordered two different sets (one set for a 92 GSR, and the other set for a 99 Civic SI) of Radiator hoses (upper and lower) and the damn things don't work. I need to know what hoses I should order. You would think that the GSR ones would work. Are the Radiator's different from an RS to a GSR?? Thanks
the bottom hose from the gsr should work. and the top one. if you need to trim to fit i would do that. or are they not big enough?
tempsohc
Aug 28, 2006 08:53 AM
SHystrdyGSRtdy
Aug 9, 2005 11:47 AM
