wiseco pistons ?
Old Apr 25, 2009 | 04:37 AM
95skunkedgsr's Avatar
Default wiseco pistons ?
ight im about to buy pistons and rods for my build and was wondering why they listed the comp ratio in a range (11.8:1-12.25:1). I was lookin at the 82mm bore one.
should i stay away form these and go with a set of cp"s ?
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old Apr 25, 2009 | 05:17 AM
GhostAccord's Avatar
Default Re: wiseco pistons ?
The way the Ebay seller has his table set up is a bit misleading.
The reason for the range is because Wiseco has there catalog set up in piston groups.
For example the catalog for one section looks like this
81mm =....K566M81 -..B18C - std. - ...
81.5mm = K566M815 - B18C - .020 - ... 11.1-11.6
82mm =....K566M82 - .B18C - .040 - ...
Check out the catalog for yourself and see...Wiseco Catalog
They all share the CR columb as a range because the diameter of a piston also changes the CR. So between 81mm and 82mm there is an 11.1-11.6 CR variation.
There is more to compression ratio than just the piston. Just because you buy an 11.5:1 piston doesn't mean you get an 11.5:1 CR. That is a number based on putting that particular piston in a certain engine setup.
Old Apr 25, 2009 | 12:44 PM
correct , i know that my comp wont be wat the piston is lol u gotta take into fact of vavles if the head been milled and so forth i just didnt under stand y they showed it in that form
Old Apr 25, 2009 | 01:36 PM
00Red_SiR's Avatar
All Motor Mentor
wat? y u tak liek dat? r u ight?
Old Apr 25, 2009 | 01:52 PM
street_of_rage's Avatar
i have wisecos in my car and they work great.
Old Apr 25, 2009 | 01:59 PM
PyroProblem's Avatar
Ha, dat sum funny chit right thur!
I agree with him, probably a range because of oversized pistons raising the compression...
Old Apr 25, 2009 | 04:48 PM
i was dropped on my head once or twice as child
Old Apr 26, 2009 | 01:30 PM
dlaub25's Avatar
for having a sense of humor!
Old Apr 26, 2009 | 01:40 PM
Ls_dx's Avatar
Is your question: Is wiseco a really nice quality piston at a great price? if so. yes
Old Apr 27, 2009 | 02:32 AM
that was one of them ,but wasn't to worried about it because i kinda knew the answer, just wanted to see if someone would come on here with a disasture* story about one
Slickrick936
May 24, 2019 02:35 PM
sonson6
Apr 28, 2008 07:44 AM
Ak_ef9
Oct 22, 2007 01:01 PM
vtec65
Oct 18, 2003 02:55 PM
