MPFI can what?!?
Old Apr 24, 2009 | 11:21 PM
shyguy4no1's Avatar
Default MPFI can what?!?
ok... hi guys I got about 50 million questions rolled inot about 3... so bear with me...
Alright here goes... I get the whole mpfi from dpfi swap thing (I am getting prepped for it soon in my 89 dx hatchback) but can you swap a head from a d16a6 on a d15? (basically si head to the dx)
Question no 2... can I put a si cam into this thing after the swap with the d15 head?
Question no 3... do I treat this like a si when it comes to parts now after things are done???
I know It sounds lame but I don't want to screw up my ride by not asking stoopid questions. thanks guys.
Old Apr 25, 2009 | 12:06 AM
~sp33~'s Avatar
EFB055
Default Re: MPFI can what?!?
The d16a6 is the Si engine. So that kind of voids question 2.
Q3: It'll depend on what parts your replacing. Name a specific part.
You can swap the heads also.
Old Apr 25, 2009 | 12:15 AM
shyguy4no1's Avatar
cold air intake, camshaft, throttle body ect. you know performance wise I don't want to screw up my engine... but the head will swap... so friggen sweet... however piston wise it will still be a d15 right? ok definately good to know...
Old Apr 25, 2009 | 12:33 AM
~sp33~'s Avatar
EFB055
Someone else will have to chime in about the pistons, I'm not sure if they're the same.
As a basic rule, everything from the head up will be from an SI. Including those things you mentioned.
Old Apr 25, 2009 | 10:57 AM
shyguy4no1's Avatar
So will I just use the si harness to hook everything up or the hybrid dx harness for a hookup if I use the si head?
Old Apr 25, 2009 | 03:44 PM
~sp33~'s Avatar
EFB055
I haven't personally done it,
Can someone else chime in?
Old Apr 25, 2009 | 03:49 PM
D16SiHatch's Avatar
you need to use the dx harness that's been converted to mpfi no matter what. unless you're swapping to a k-series engine, you will retain the stock harness.
Old Apr 25, 2009 | 04:10 PM
sinepome's Avatar
i hve a quick mpfi question. not to jack.
can i use a harness from a da teg to do the swap?
not just the harness but modify my dx one with the da one?
thanks.
Rickdogg
11
Aug 28, 2009 02:02 PM
1991hb
Oct 27, 2006 08:22 PM
ef u
15
Oct 15, 2005 01:31 PM
Dorifto13B-T
Jul 23, 2003 12:09 PM
Josho_17
Mar 16, 2003 10:35 PM
