97 spec Type R flywheel in Cable Tranny?
I have a flywheel and pressure plate both from a 97 Type R Integra.
I'm currently assembling my first gen SiR engine for my CRX and was wondering if the ITR flywheel and pressure plate will bolt on to the cable B16 tranny that I was planning on using?
I know that the ITR parts are off of a hydraulic tranny but I don't know much about transmissions and wasn't sure if that is of any significance when assembling the flywheel, pressure plate, and clutch into a cable tranny.
Thanks!
Thanks!
doesnt matter what tranny your using b-series flywheel works on a b series motor, cable or hydro has no affect on that.
just torque it down to specs.
what you need to know is mostly all cable b16 trannies will need a 90-91 integra clutch.. S1's, J1's and Y1's.. these trannies require a 190mm disk spline
ys1 gsr/ls cable trannies use a 92-93 clutch. and these require a 200mm disk spline.. holler if you have any questions!
ef0cmacro
Apr 5, 2010 07:56 PM
lilxvtecxpwr
Feb 11, 2005 11:47 AM
