building the perfect 300 whp motor
Old Apr 24, 2009 | 09:49 PM
madmike311x's Avatar
New User
Default building the perfect 300 whp motor
ok so first off i will tell you what car this will be going into. It will be a 1998 acura cl 2.3 premium 5 speed
ok so the goal is to build a very reliable 300whp DD as cheap as possible.. let that battle begin!
possible options i was suggesting.
1.f23/h22 head with a built bottom end/turbo
2.h22/turbo
3.k24 setup,, i know the k series are more expensive but it cant be ruled out
Old Apr 24, 2009 | 09:53 PM
Nick Z32's Avatar
Default Re: building the perfect 300 whp motor
k20
Old Apr 24, 2009 | 10:35 PM
New User
im hearing the g23 is the way to go. also keep in mind this is going into a heavy car
Old Apr 25, 2009 | 07:01 AM
2fastGSR's Avatar
King of the One Liners
I think you have a lot more research to do
Old Apr 25, 2009 | 07:04 AM
gibsanez's Avatar
Have fun.
Old Apr 25, 2009 | 01:48 PM
alterdcreations's Avatar
turbo is the best bet for reliable 300hp. but you can keep the 2.3 and get the power form boosting it
Old May 2, 2009 | 12:00 PM
bsivoljr's Avatar
they say no replacement for displacement 2.4
Old May 2, 2009 | 02:29 PM
thehatchninja's Avatar
100% stock block turbo F23. 300whp is a relatively low number, some may consider it pretty high for a stock block, but i'd do it, then buy a F/H to build later. (built would obviously be more ideal, but you DID say cheap as possible).
Old May 2, 2009 | 03:03 PM
h224thgensedan's Avatar
if you go with the h series some coins better be set aside for some bottom end work. The G series builds can put out nice numbers but you need to have an understanding of the motors.
mindless4banger
Engine Machining & Assembly
Jan 29, 2016 09:08 AM
darkestfenix
Feb 17, 2010 08:54 AM
mongtite
Oct 23, 2008 08:36 PM
ilovemyrex
Jul 20, 2005 02:12 PM
allmotorek8
Jun 4, 2005 01:24 PM
