Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Koni yellow adjustment
Old Apr 24, 2009 | 09:14 PM
Conan the Destroyer's Avatar
Default Koni yellow adjustment
im wondering about the twisting adjustment of koni yellows...
putting the shaft in a vice and twisting it 180,360 or 720.
did anyone mess with this?
car is ek4 si-r,b series, ground control 430 front 550 rear, spirited street/gymkana, 205 50 15 direzza star specs
thanks for any insight.
Old Apr 25, 2009 | 09:26 AM
alphalanos's Avatar
Default Re: Koni yellow adjustment
Dont they come with the plastic ***** to adjust the rebound?
Old Apr 26, 2009 | 11:39 AM
JayK's Avatar
It should just be a small tab at the top that you can twist with either the provided white adjuster ***** or some needle nose pliers. The Yellows are rebound adjustable. When the adjustment is turned completely to the right (clockwise), that is full soft. Turning to the left (counter clockwise) will make the damping more hard, but I believe that the adjustment runs out after about 2-2.5 turns CCW.
Where did you get 205/50/15 Star Specs? I want some of those, I got em in 195/55/15 and as far as I know, are only available in the 195's in the States.
Old Apr 27, 2009 | 04:21 AM
b16a1eg6's Avatar
I think that is only for the Red shocks.
http://www.koni-na.com/adjustment.cfm
Conan the Destroyer
Suspension & Brakes
Apr 27, 2009 10:06 PM
ej1b18b1
Mar 26, 2009 02:14 PM
daily
Suspension & Brakes
Mar 21, 2006 09:51 PM
kliq
May 13, 2003 05:53 PM
GSpeedR
Oct 15, 2002 10:17 PM
