Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Hond Civic EX Overheating
Old Apr 24, 2009 | 05:11 PM
Exitialis's Avatar
New User
Default 2005 Hond Civic EX Overheating
I've recently noticed that my Civic overheats after driving on the highway. The car is fine when driving anywhere else in town. The heating problem isnt really an issue while on the highway, only when immediately exiting the highway onto local roads. The coolant gets to a boiling state and starts to overflow from the overflow tank. There does not appear to be any leaks elsewhere. I have already replaced the thermostat with no luck. Both fans on the radiator appear to be running properly. Someone recommended that I turn the heat on full blast if the problem occurred again in order to lower the engine temperature. I did that and noticed cool air coming through instead of hot. Anyone have any suggestions?
Old Apr 24, 2009 | 07:28 PM
dtapia's Avatar
Default Re: 2005 Hond Civic EX Overheating
sounds like the system is empty
recheck your coolant level when it cools down or first thing in the am.
Old Apr 25, 2009 | 11:00 PM
keeler's Avatar
Have you properly bled the system? It could be air in the lines.
mimog3
Jul 21, 2013 07:31 AM
14psi
May 15, 2013 07:29 AM
ddockins4010
Aug 11, 2010 08:58 AM
EM2ner
17
Jan 14, 2008 06:23 PM
