crx sir spoiler install help
i ordered my jdm crx sir spoiler today and have been doing a lot of research. some say the usdm rear wiper from the crx wont work. you need the jdm one or i heard the integra 90-93 will also work.
has anyone done this install on there 1988 crx si? any info or step by step installation guide would be nice. pics also. let me know thanks.
also mine doesnt come with the nuts, does anyone know if any 10mm nuts from a honda will works?
help just got my sir spoiler and 90-93 integra rear wiper arm and gonna try to install tomorrow. does anyone know if everything will fit? i have seen posts where some people say that the arm is all you need to replace and other where they said you need the jdm rear wiper motor.
anyone????
anyone????
You need the jdm wiper motor that is specific to that spoiler. The spper sits about 1/4 inch lower which allows for clearemce. Just using the DA wiper arm wl not clear.
i got my spoiler and integra arm to work. my spoiler is not lined up 100% correct, it is about 1/2in back. looks okay from a distance, but at least my rear wiper works. i will adjust it and make it flush if i can ever find a jdm wiper motor.
yes the canadian SE model crx has the same wiper motor as a jdm crx, but ONLY if it had a spoiler, otherwise it would be the same as ours. i called a Canadian dealership a while back and they said there was only a "SE" model in 91 and the only difference according to guy was the spoiler.
i only put nuts on 3 bolts because i didnt know there was bolts under the plastic pieces that were on it. i only picked up three. on my 88 i ran into a issue of a plate covering the passenger side where the bolts came in on the trunk lid so i couldnt get one of the nuts on that side. i am gonna pick up 2 extra 10mm nuts and try to find a way to put them on. it is pretty secure with just the 3 nuts.
