misfiring @ low load/rpm after fully warms up.
Old Apr 24, 2009 | 12:16 PM
RACEPAK's Avatar
Default misfiring @ low load/rpm after fully warms up.
hello everyone.
i have a misfiring/sputtering issue after full warmup for a while now, even before i installed the current engine/setup mentiond below i had it, it wasnt a big deal when runing with crome because i assumed crome was the issue,
sympthoms are:
-when cold until fully warm its runing fine,
-after about 25-30 mins of driving when coming back to idle, the engine misses randomly and bogs at idle rpm every few cycles.
-as i rev it up to 1500 rpm it missfires alot (in random cylinders i think), somtimes pulling the rpm by itself to 1300 rpm,
-at 1500rpm+ it just missfiring bad,
-at driving start the engine bogs abit for a second and regain power, (transition from high vac to lower vac)
-at light cruising it misfires just a tad, it just not powerful enough to be felt.
logs and tune are OK,
things i allready tried by order:
changed engine (75.50 vitaras / 59300 cam)
new wires
new dizzy cap + rotor
new plugs
new coil
new icm
borowed a dizzy from a friend
several p28 ecus
resoldered main relay
-97 civic
-"new" p28 ecu + ectune
-new 780cc precision injectors
-new 4bar hondata map (it did it with the stock map)
-venom intake manifold (disabled iacv, ON fitv, disabled purge valve)
-walbro 255 with a relay, switched by the main relay, grounded to the car body next to the pump,
-3 big fat engine ground wires,
-calibrated tps
any ideas guys?
thanks a bunch
Old Apr 25, 2009 | 04:44 PM
mtber's Avatar
Default Re: misfiring @ low load/rpm after fully warms up.
Sounds like a wiring issue. Have you checked over your wiring harness or considered replacing it ?
Old Apr 26, 2009 | 02:51 PM
RACEPAK's Avatar
hello,
well i checked the dizzy harness yesterday and it seems ok, other then that the rest of the harness was modified by me not too long ago (had this problam before), so i trust it,
also,i just ordered me a aem 30-1040, and i might try a cop setup(twin fire/epm/01+coils). so yeah i might redo the whole engine harness,
Old May 1, 2009 | 05:22 PM
RACEPAK's Avatar
bump
Old May 2, 2009 | 05:00 AM
mtber's Avatar
This may sound stupid, but have you done a compression & leak down test ?
Old May 3, 2009 | 10:38 AM
RACEPAK's Avatar
yup, 150 all across
Old May 3, 2009 | 02:22 PM
Garage 808 Hatch's Avatar
have you tried a new fuel filter??
my EG ran like crap at light load after warm, in my case, a fuel filter fixed it
Old May 4, 2009 | 01:02 AM
RACEPAK's Avatar
just did a second comp test, it was 160 all across
i change my fuel filters quite often, (no where near the service limit) but thats an idea, ill try to replace it,
Old May 7, 2009 | 04:31 PM
maddog20's Avatar
do you have a 100% oem/stock ignition setup?
Old May 8, 2009 | 04:37 PM
RACEPAK's Avatar
yup
Old May 8, 2009 | 05:25 PM
non-VTEC's Avatar
air/fuel ratio when fully warmed up? if you add a bunch of fuel does it go away?
my rc750's have a random pop/miss at idle. can't get them to run very smooth with ectune.....i suppose i can i just need to spend a **** load of time going thru all the settings.
check your battery voltage/compensations also.
mrbamb
Honda Motorcycles
Sep 11, 2017 09:01 AM
bazzynga
Honda Civic (2006 - 2015)
Sep 6, 2011 08:51 AM
wi_accord
Jan 3, 2006 01:52 PM
nonv
Dec 3, 2004 08:11 AM
lococoin
Nov 23, 2003 04:18 PM
