F2b build
Old Apr 24, 2009 | 06:51 AM
ej6.sean's Avatar
Default F2b build
I recently acquired an F20b from an accord with a spun rod bearing.
planning to rebuild the block with an f23 bottom end using the rods and crank.
I was told you can use K20 pistons, what modifications have to be made for them to work?
Old Apr 24, 2009 | 03:58 PM
ej6.sean's Avatar
Default Re: F2b build
come on H-T I know somebody put k20 pistons in an F20 before
Old Apr 26, 2009 | 09:41 PM
ej6.sean's Avatar
bump.
Old Apr 27, 2009 | 04:38 PM
ej6.sean's Avatar
tttttttttttttttt
Old Apr 28, 2009 | 10:46 AM
ej6.sean's Avatar
bump for some info
Old Apr 29, 2009 | 07:37 AM
hondaZvic's Avatar
this should help you:
https://honda-tech.com/forums/hybrid-engine-swaps-18/build-thread-1-f2d-cheap-2499107/
Old May 1, 2009 | 05:40 PM
ej6.sean's Avatar
thanks
Old May 1, 2009 | 06:07 PM
boostedmonkey's Avatar
Why don't you just use the F23 motor. It's a stout block. Will take boost well, should you decide to do that. You could always Frankenstein it with an H22 head. Are you talking about the F20B that came out of the Euro Accord? The blue top?
Old May 1, 2009 | 08:49 PM
ej6.sean's Avatar
Yes the Euro Accord is the one I have, I want to keep cause it revs up to 8k stock
Old Jul 9, 2009 | 10:54 AM
hondamark35's Avatar
so you're wanting to put the F20B rotating assembly in the F23 block and reuse the F20B head?
the K20A pistons are the ones that will work in the F23A block. you'll need something different for the F20B block as the bore is smaller. i've not researched it yet, but i think the F20B rods are different from the F23A, as well as compression heights.
Old Jul 9, 2009 | 05:02 PM
ej6.sean's Avatar
no im using f20b block f23 rods k20 pistons
Old Jul 9, 2009 | 05:27 PM
so you're boring to block to fit the pistons?
Old Jul 9, 2009 | 08:29 PM
ej6.sean's Avatar
k20 f20 same bore..
Old Jul 10, 2009 | 03:08 AM
Originally Posted by ej6.sean
k20 f20 same bore..
86mm? we need to correct the H&F series FAQ if so, it shows 85mm.
Old Oct 7, 2009 | 05:54 PM
ej6.sean's Avatar
actually i did have to bore out the block came out nice just waiting for my head to come back now
Old Oct 11, 2009 | 06:31 PM
NABeastRR's Avatar
is the f20 block iron sleeves?
as far as what mods need to be made nothing if there forged unless runing big cams then you have to clay the motor & maybe flycut them.
if there oem pistons then the offset is wrong & they sit in the block backwards so youd have to have your valve reliefs open on the exhuast side to match the bigger intake vlave.
rdx injectors you can use im sure some sort of space will be needed....trial & error
Old Oct 11, 2009 | 06:34 PM
ej6.sean's Avatar
the pistons are not in backwards and the sleeves are FRM running stock cams
Old Oct 11, 2009 | 07:02 PM
NABeastRR's Avatar
are you useing stk k20 pistons or forged pistons?
Old Oct 11, 2009 | 07:06 PM
ej6.sean's Avatar
stock pistons k20z1 i believe
Old Oct 11, 2009 | 07:10 PM
NABeastRR's Avatar
hmm ok ill have to double check everything then everything ive learn they sit in the wrong way if there stock becuz of the off set.
robbizza
Nov 14, 2008 03:26 AM
lilneedle
Aug 14, 2005 04:54 PM
Sam1am26
May 4, 2005 05:40 AM
Lip
Oct 2, 2003 05:31 AM
hatchizzle
Mar 14, 2003 02:01 AM
