95 civic ac problem
Old Apr 24, 2009 | 04:54 AM
Nurvcom's Avatar
Icon3 95 civic ac problem
ok i just had new ac compressor installed
well it will get cool air but not cold like it use to be
and when i get up to 5000 to 7000 RPM the ac pump squeals
i just check to see if ac coolant (R134) was high in sun light no was in spec but i purged some and it coming out gray not green
Old Apr 24, 2009 | 06:38 AM
Former User's Avatar
Default Re: 95 civic ac problem
Might the squealing sound actually be coming from the idler pulley?
Did you check the refrigerant pressures on both the low and the high sides with a manifold gauge set in the shade? What were the numbers?
Was the dryer replaced and the system evacuated prior to recharging?
Old Apr 24, 2009 | 07:05 AM
rick_rabies's Avatar
I'm not Rick!
you dont need it anyhow. rip it out
pj08006
Aug 27, 2018 04:28 PM
Dustin Knauff
Honda Civic (2001 - 2005)
Jul 2, 2018 07:57 AM
Ef4doorwagon
22
Jun 13, 2015 07:03 AM
vietnogi
May 24, 2005 08:01 AM
