Skunk2 LCA's won't go in.
Old Apr 23, 2009 | 09:31 PM
Ldo's Avatar
Ldo
Default Skunk2 LCA's won't go in.
Anyone else had issues with installing the Skunk2 LCA's? The bushings are too wide and tight that there is no wiggle room to get the bolts thru. Any suggestion?
Old Apr 23, 2009 | 10:05 PM
EJ1_Sleeper's Avatar
Default Re: Skunk2 LCA's won't go in.
grease the bushings first and man up and shove it in there?
make sure there ment for your year as well. buddy just got some skunk2s that were for an EG/teg instead of an EK.
Old Apr 23, 2009 | 10:17 PM
rival12's Avatar
yeah even some dish soap will help, also....and i just finished putting on some lower control arms haha...
Make sure your bolts have that long pointed end.
One of my bolts when i took it off, then end was too rusty it fell off....i tried to get it in for hours....luckily i had a spare bolt from the junkyard....
Without the long smooth pointed end, the bolt cannot set itself. What i did, was took a small screwdriver stuck it through the hole, and then through the LCA hole, and wiggled until it lined up, or just enough so i could shine a light through one side, and see it through the other. Then you stick that pointed part through, gently tap with a hammer, and it will slide itself into place until you can start threading.
Goodluck.
1990IntegraLS
Jun 27, 2019 01:20 PM
tooters bmx
Oct 6, 2017 11:01 AM
FredrikL
Suspension & Brakes
30
Feb 3, 2012 02:04 PM
digital sol
Suspension & Brakes
Jun 2, 2009 03:41 AM
ninetysevenITR
Apr 14, 2008 06:58 PM
