fluctuating idle and jumpy speedometer needle
Old Apr 23, 2009 | 08:09 PM
MD-Type-R's Avatar
Default fluctuating idle and jumpy speedometer needle
Car:
01 ITR with JDM ITR
Recently Replaced w/ New Tranny (thanks Irev1210 awesome dude )
For some reason when I first start the car it idles normally (slightly high at cold start) and then drops normally. As soon as I give it a bit of gas or drive the car and come to a stop I begin to have a consistent idling surge ( from about 900 - 1500k). If I shut the car off and restart it, the surge is gone until I gas / drive again.
The car drives normally besides my speedometer needle randomly jumping around sometimes. It will sort of spike then drop low for a few seconds, kinda like a cracked out teenager The odometer moves normally and RPMS are displayed correctly.
Anyone have suggestions as were to begin troubleshooting?
Old Apr 24, 2009 | 04:02 AM
NA_ITR's Avatar
Default Re: fluctuating idle and jumpy speedometer needle
Originally Posted by MD-Type-R
Car:
01 ITR with JDM ITR
I had this problem when I took off my tranny for a rebuild. After installing it back my speedometer jumps around at mid and high range rpm. Took it to a local shop and replaced my speedometer sensor plug (located on the tranny) after switching the plug it went away. Doesn't hurt to try
Old Apr 24, 2009 | 04:10 AM
97CWITR's Avatar
Clean out your IACV as well! That'll help your surging idle.
Old Apr 24, 2009 | 05:05 AM
totsie7944's Avatar
I am willing to bet its your IACV causing you some issues, or its loose maybe. Take it off and clean it.
Old Apr 24, 2009 | 06:18 AM
Mugen Type R's Avatar
Make sure your grounds ont he motor and tranny are good everywhere. I had that happen to me on my RS and idle would jump, needle wouldn't only jump though, it hit 0 and went back up! total motor stopped at one point. So check the above stated and if all else fails, make sure your grounds are good! It'll save you some time!
Old May 1, 2009 | 06:08 PM
dannysolis92005's Avatar
Car:
01 ITR with JDM ITR
sorry to bring this thread back but as i was serching i came across this post. i have the same problem i am running a jdm itr engine on a 91 honda civic si ( sorry its not an itr)nuts on me and my vtec wont engage. heres a vid. thats me holding it steady at 3k rpms
th[URL=http://s98.photobucket.com/albums/l260/dannysolis92005/?action=view&current=Video-0007.flv][IMG]http://i98.photobucket.com/albums/l260/dannysolis92005/th_Video-0007.jpg neddle goes
kenneek9
Jan 11, 2013 08:25 AM
B18cHatch06
Feb 23, 2006 11:36 AM
