35 offset camber?
Ok stock offset on 97 civic is 45, went with buddyclub sf challenges 35 offset 15x6.5, kuhmo 205/50/15's with tokico illumina full suspension kit= 1.5" drop, sk2 rear camber kit. Problem is under cornering both front and rear tires rub, any suggestions on a dialed in front and rear cmaber that will avoid the rubbing issues?
Hmm, I really don't think anything should rub with that size tire/wheel offset and such a moderate drop. Unles your **** is straight up almost bottoming out nothing should rub.
Where exactly is it rubbing? If its the outer fenders just roll em.
Ok, front tires rub on I believe the liner only, but I really don't want to remove, due to cai, and the rears rub on the qtr pnl/fender, I could roll em but thats like $200, I guess I'll just hve to wait till tires wear out and buy new 195's, I think I got oem specs fo the camber so I don't run through tires, what were you guys running for neg cam?
I cut a rectangle patch out on the top of my fender lining where the tires rub because I didn't want to take it completely out. As for the fender rolling, I was only charged $25 each fender.
I think I'll try notching my liners, they are shot anyway, and when it's time for new tires (195's) down the road I'll just try to score some new liners
mynameizstitch
Jun 4, 2012 04:04 PM
Halo
Dec 25, 2004 04:29 PM
danyerudono
14
Aug 24, 2004 06:39 AM
