*************** JDM_MOB's SUPER SALE ***************
All parts in perfect working condition. Enjoy
I also have a 97 Orginal GS-R Shell Converted RHD With a JDM Front for sale. SOLD
New: $150 K-Sport Springs / Drop: 2.5" Front 2.25" Rear / DC, EG, & Del Sol
New: $450 CP 81mm Bore 9:0:1 Pistons W/ Wrist Pines, Locks, Rings & box
New: $280 Eagle Rods H - Beam W/ ARP Rods Bolts
New: $150 Ajusa Complete B18C1 gasket set (81mm)
New: $75 ACL Rod Bearings B18C1
New: $75 ACL Main Bearings B18C1 .25 over
New: SOLD ARP B - Series Main Studs
New: $30 OEM EDM/UKDM Honda Embelem
New: SOLD OEM Integra Type R Shift Boot
Used: $130 Meutek B - Series Log Manifold A/C and P/S Friendly
Used: $250 UKDM EG VTI ESI Cluster (Lights up amber)
Used: $250 EACH (4) Sets of JDM Integra Type R Rear Seats
Used: SOLD B - Series Passenger Side Axle
Used: SOLD EK 99-00 Fog light Covers/Housing
Used: $25 98-01 Passenger Side Integra Tail Light
Used: $25 GS-R Power steering Pump
Used: SOLD GS-R T-Bracket Rear Mount
Used: $125 JDM Integra Type R Wire Harness
Used: SOLD B - Series Starter
Used: SOLD (VSS) B - Series Vehicle Speed Sensor
Used: $30 Integra LS Header
Used: SOLD B - Series Half Shaft
Used: $75 OBD2 to OBD1 Jumper Harness
Used: SOLD Sockted OBD1 P28
Used:Sold 13' Spare/Donut
Used:SOLD 95' B18C1 GS-R Transmission W/ Shift linkage (4th gear slight grind)
Used: SOLD 98' Complete B18C1 GS-R Vtec Head (Completely Rebuilt, New seals, hot tanked etc etc
Used: SOLD B18C1 Legit with V.I.N Bare Block & Crank... Block was decked, honed, hot tanked. Crank was Micro Polished, Cleaned, Cut .25 over, Balanced and Rotated to 15k RPM's. Everything done by Elite RPM in South Miami. The main caps, brackets, water pump, bolts etc ect are all bagged up.
The GS-R head is the one with the purple valve cover one.
GSR Tranny - SOLD
B - series half shaft - SOLD
B - series axle - SOLD
Block & Crank - SOLD
GSR Rear t- bracket - SOLD
B- series Shift linkage - SOLD
__________________
__________________
