z6 swap ef please help
Old Apr 23, 2009 | 06:29 PM
dokdok's Avatar
Default z6 swap ef please help
ok i did the swap and it turns on but it has a code but its not reading it i tried and tried but no code and i idles for a few seconds and stops and idea guys thanks
Old Apr 23, 2009 | 06:31 PM
dokdok's Avatar
Default Re: z6 swap ef please help
idk i think the dizzy is wrong it sits side ways not like my friends b seies which the cap has the two top screws paralel there side ways idk if thats the way it should be
Old Apr 25, 2009 | 08:01 PM
ChrisHinds's Avatar
mine was a bad map sensor.... make sure none are cut torn whatever
Old Apr 25, 2009 | 09:30 PM
ivanson's Avatar
map sensor. check if you dont have map and tps connector swap and wutknot
but yea happen to me map senosr was not hooked up
Old Apr 26, 2009 | 09:12 AM
93formula's Avatar
did you do a obd1 swap? is the firing order correct?
ef9gonzalez
Oct 11, 2012 06:48 AM
atmdc
11
Nov 15, 2007 09:28 PM
JasonST
Apr 26, 2006 07:36 AM
j-robsDA
May 31, 2005 08:08 AM
