ST REAR sway bar
Can somebody post up some pics of how you install the endlinks to the shock on this? I've gone through all the archives and can't find any active picture links
or can somebody tell me how the bracket bolts up to the shock/lca? There is one side with 1 hole, then the other side with 2 holes. Which goes where?
awesome thanks man!
I take it that the car should be on the ground with the bar loose before you go around and snug everything up? Also i flipped the heim joint link around from in those pictures so the shaft is on top and the thread bolt is on bottom to give me a bit more space between the shock mount.
How do you determine how stretched that link should be? I found if i gave it more lenght it gave me a bit more clearance for the heim joint shaft to clear the shock bracket...
Driven
18
Mar 30, 2006 11:53 AM
poop32145432
24
May 27, 2004 05:02 PM
