Windshield wipers are weak
My windshield wipers are very weak. When driving on the interstate, I can't use them because the wind flips them up and they get stuck up there. Is this a common problem? Would it be the motor that needs changed, or something else?
damn. ive never heard of this happening. my guess would be the motor or relay of some sort. just use rainx on your windows and problem solved. i have never used my wipers since ive had my ef.
Do you mean that
a)the wipers stay at the top of the windsheid and don't go down?
or do you mean that
b)they don't touch the glass properly but still move up and down?
a) If your wiper motor is getting the correct voltage, it is on its way out.
b) You can replace the springs on the wiper arms.
Your squirter is entirely separate. It is a small pump that is at the base of your washer fluid reservoir. If it is getting power and not working, replace it.
or do you mean that
Do you mean that
or do you mean that
or do you mean that
Yea, my squirter has never worked. The lines cracked when I opened my hood, so I just yanked them out
I would check the voltage reaching the motor -- if it is correct (sorry, I don't know what that is off hand) it is probably time to replace the motor.
h22chilton
13
Mar 23, 2006 10:36 AM
