will hydro b series clutch work in cable b series tranny?
like it says, my friend has a ef with a b series swap, i have a used clutch thats from a hydro setup and was going to give it to him to help him out since his clutch is shot. was wondering if it would work ok or not? and if not why not? thanks!
does it have a sticker on it? A YS1 ls tranny or gsr can use your clutch and I'll have to look up the code for the b16 transmissions.
*Some s1 transmissions will be able to use it and as mentioned before, ys1 transmission. If it doesn't have a sticker, slide the clutch on the transmission and hold the mainshaft, then move the clutch around and see if it has any play. There will be a tad with the right clutch but you'll know when it's too loose and the wrong one
ok, i'll try that, he said he thinks its from a 91 gsr. but i'll take and slide it on the input shaft and see how it fits. thanks!
^^ your right they didnt, i didnt catch that when i asked him if he knew what year it was. i still havnt tried it yet.
make sure you check it closely. They're a really close size. If you are unsure just wrap a piec of wire around it and twist it tight, then move it to the other input shaft
nolakid504
May 23, 2009 10:02 PM
dingusjt
Dec 7, 2003 08:25 PM
