b18 swap in EF rear mount help!
I swapped in a B series into my 91 hatch and Im having a issue with the back metal piece that bolts onto the rear mount/tranny. I received a mounting bracket for this whole swap going into this model civic, but it does not fit, to big. I searched for the 91 integra bracket and i came down to this part number 50827-SK7-020 , correct me if im wrong but is it this the right bracket that im needing?
any help would be appreciated
Sorry at work cant see pics but it should be a T looking piece that attaches to the motor sorry if that doesnt help. If you look on my website there is a pic of 2 of them on the for sale page for reference
i found that part number on hondapartsunlimited ill order it today, and thanks
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-my-swap-parts-list-b18c-s2-im-into-91-crx-dx-953089/
but heres the bracket, it looks like the 94+
i have heard this too, about folding the lip on the rear. some say they didnt need to do it, and some say they had to. i guess it depends on which mounts you are using.
i just did this mountbracket after motor and trans in.
up on lift and it went right in through bottom
no problem to bolt up to motor/trans
had to pry on the motor to line up bolt at mount and went right in
i didnt have to cut or bend the rear cradle
but i might be on it or hitting, cant tell,
I'm not sure of the part number either, but I ordered the bracket for my b16 swap in my crx from a 91 ls. didnt have to cut or bend anything to fit onto the rear mount
alright im bringing this back up to the top. installing the motor right now, and it seems that the lip is deff in the way on the rear cross member to bolt the tranny bracket up. just for reference im using the Avid mount kit
I just got that T-bracket from my local junkyard.
yea ill be pulling the motor out tomorrow and bending the lip down to clear my bracket. just wanted to put this info out there, cause i dont see many people mention it.
