i-vtec on stock type s
Old Apr 23, 2009 | 10:45 AM
djmyst305's Avatar
Default i-vtec on stock type s
How does it pop? i just sold my teg and know what vtec is supposed to be like, but on my new stock type s, its barely and i mean Barely noticeable, i dont hear it, and if i am really trying to test it, it barely does somthing. 58000 miles, shortram intake, magnaflow exhaust.
Old Apr 23, 2009 | 11:10 AM
josh's ep3's Avatar
Function > Form
Default Re: i-vtec on stock type s
You sure you have a Type-S??
Old Apr 23, 2009 | 11:11 AM
josh's ep3's Avatar
Function > Form
Nvm ^ Maybe it's not crossing over at all, are you low on oil?
Old Apr 23, 2009 | 11:14 AM
djmyst305's Avatar
fresh oil, k20a2, something kicks in at 5800 when slowly pressing the gas till 5800.no pop or anything, but so little of a push its not knoticable at all.
Old Apr 23, 2009 | 11:19 AM
nahonda04's Avatar
Surje.motorsports
Better make sure its not an a3 lolol!! Get a better intake and some race header. U will hear it more than!! How far into the rpm fo go after engaging at 5800? It progressively get louder into the rpms!!
Old Apr 23, 2009 | 11:30 AM
djmyst305's Avatar
i take it to 7900 as if i was racing to see how its running. everythings good but i dont feel vtec, or atleast the not way it should be for a better motor then i had in my teg
Old Apr 23, 2009 | 11:33 AM
skillfull19's Avatar
You can barely hear the crossovers on the RSX's... that's why I got the ARC intake.
Old Apr 23, 2009 | 11:38 AM
djmyst305's Avatar
i dunno then.. this car just seems slower then my teg. good low end power, but when it comes to vtec and high rev, my teg would have blown it away.
my teg had work done, but nothing really power wise.. b16head ls block,itr cams, itr intake manifold, cold air,dc headers,test pipe, and 2.5 exhaust,
this indeed makes the sound, but my teg climbed so fast in vtec/rpms towards the type s
Old Apr 23, 2009 | 11:41 AM
EM2Civic's Avatar
K and B is night and day espically in N/A... get a 3" exhaust and intake then if you want to feel the crossover or Kpro.
Old Apr 23, 2009 | 11:49 AM
djmyst305's Avatar
I drove another RSX type s with a 3 inch forza tuning pipe and headers with intake. and still didnt hear crap, but also same as mine, barely noticeable
Old Apr 23, 2009 | 11:55 AM
nahonda04's Avatar
Surje.motorsports
Wut?! U went with an airbox to hear vtec engage more. Cai is the best way to go. All that box is bling!!! I cud hear my crack loud when i didnt have kpro and even better with kpr0
Old Apr 23, 2009 | 12:03 PM
adam00's Avatar
can you make a video of your speedo and rpm gauge when driving
Old Apr 23, 2009 | 12:13 PM
josh's ep3's Avatar
Function > Form
I heard that the less you hear or feel you vtec the better the tuning is on your motor. I could be mistaken but maybe it's better to have a smoother transition.
Old Apr 23, 2009 | 12:51 PM
djmyst305's Avatar
ill make a video tonight when i get off work, and for the vtec transition, i would hope that this car has more power then that for a type s. for when vtec kicks in i dont feel any faster, same climb speed in rpm.
Old Apr 23, 2009 | 12:52 PM
djmyst305's Avatar
from the factory whats the true stock hp? what should i be expecting
Old Apr 23, 2009 | 01:01 PM
Tyte-S's Avatar
Why would you want your VTEC to "pop"...It is a more of a smooth transition...Not a "poppin vtec yo"... The K series will not "pop" like the B series use to anyway. I'm not quite sure what you are expecting..
If you think something is wrong...Do a compression test. Yank the spark plugs...do a dry test then a wet test. I think you can rent the Snap-On tool from AutoZone. For the wet test...add a cap full of ATF into each spark plug before you do three cranks of the engine. Then right the info down and get back to us.
Old Apr 23, 2009 | 01:02 PM
Tyte-S's Avatar
If you have an '05....Your BHP is 210...For an '06 it's 200...And for the '02-'04...It's 200.
Old Apr 23, 2009 | 01:04 PM
djmyst305's Avatar
i know all that, i am asking True hp if i put a stock on the dyno, it isnt gonna tell me 200..just like the gsr is 180, i know it wont show that
Old Apr 23, 2009 | 01:11 PM
Tyte-S's Avatar
Every car is going to vary dude...based on mods, mileage, what dyno you use, weather, altitude...You can expect to be in the high 170's stock...Depending what dyno you are using.
Old Apr 23, 2009 | 01:24 PM
djmyst305's Avatar
that second part answered my question,,
will do the video, and let you guys tell me if it looks right or not.
Old Apr 23, 2009 | 06:58 PM
camel_dc5's Avatar
hmmmm
mine pops hard @5800
dont know why ur having problems?!?!?
Old Apr 23, 2009 | 07:00 PM
camel_dc5's Avatar
stock whp on my 06 type s was 165whp & 134wtq
Old Apr 23, 2009 | 07:34 PM
kobeballer96's Avatar
u got ripped off with a k20a3 brotha
Old Apr 23, 2009 | 08:04 PM
Tyte-S's Avatar
That's really low. I'm curious to know what dyno you used.
kobeballer96:
One easy way to check if you got stuck with a k20a3...Is look for the stamp on the block.
But we know this isn't the case since he already said he takes it to 7900 RPM's...Reading owns you.
Old Apr 23, 2009 | 08:07 PM
kobeballer96:
i know about the stamp on the block and i just though mabey the ecu was tunned diffrent and it allowed it to take it to 7900rpm. i know u can take it to 7300 safely i herd or im not too sure but stock is 6800
