Custom DC2 brake setup question. For experts!
I have a dc2 integra and I want to tuck in the brake lines and make a simple brake system. I will use the front output of my 1in Master to feed the 2 rear brake lines true a Willwood Proportioning valve and then I will take the rear output of the same master to feed the 2 front brake line.
Here my concern!!
I wonder if I will have enough brake fluid volume to feed the 2 front calipers on one output of the master. I wonder because on the normal honda setup the front output of the master feeds the front left caliper and rear right caliper at reduced pressure and the same for the same for the rear output of the master. Therefore my theory is that alot less fluid volume is needed since the rear capliper take less volume due to smaller caliper piston and reduced pressure.
Let me know what you think and also if you have experienced this setup using stock MC.
Here my concern!!
KRaZee_TiNy
Suspension & Brakes
Jan 30, 2009 06:30 AM
