***Greddy Kit for B16, RC Injectors, Charge Piping, Apexi BOV, E-Manage, Gauges***
Old Apr 23, 2009 | 05:58 AM
WhiteSlips's Avatar
Default ***Greddy Kit for B16, RC Injectors, Charge Piping, Apexi BOV, E-Manage, Gauges***
[SIZE=5]I am posting this for a friend as he does not frequent these forums. PM me if you have a serious inquiry, thanks.
Parting this kit out. Items are going quick. Not interested in any trades.
* $1500 - Greddy 18g kit (turbo, cast manifold, heatshield, downpipe, air filter, steel-braided feed and return oil lines, AN fittings, b16 oil pan w/ welded AN fitting, OBD1 distributor [can only be turned to 14 deg, good for retarded timing], clamps, vacuum lines, heat wrap, original box and manuals, etc.- you will need charge pipes but I'm including left overs from the original kit) DO NOT WANT TO PART ABOVE ITEMS!!!!
* $250 - RC 310cc injectors (comes with wiring clips and o-rings, super clean!)
* $220 - charge piping Custom made for civic eg with b16 (by Alternative Motorsports, comes with high quality t-bolt clamps)
* SOLD - JRC black anodized intercooler (rare! no longer in production, good up to 300hp)
* $160 - Apex'i twin chamber blow-off valve (comes with original box)
* SOLD - Golden Eagle hi flow fuel rail
* SOLD - Greddy e-Manage + Giff-Tech software and data cable (comes with e-Manage wiring harness)
* SOLD - Autometer Phantom II Boost and Oil Pressure gauges (white led, comes with Carbon fiber look DIN size gauge holder, vacuum lines and original boxes)
* SOLD - High flow cat
* $70 - Golden Eagle oil sandwich (fits between the filter and the block - allows you to feed clean oil to the turbo and also tap for an oil pressure gauge)
* SOLD - Golden Eagle vacuum manifold
Near mint condition custom Greddy 18g turbo kit for the honda civic b16. I bought everything brand new about a year ago. This kit has only seen about 4000 - 6000 mi. worth of use, so it's still like new! I'm selling this because I'm parting out my car, I need the money to pay off debt. I am NOT interested in any trades. I need the cash.
This started out as a basic Greddy Kit but there are a ton of extras! All the piping was custom made by Alternative Motorsports. The kit was also professionally installed and tuned by Alternative Motorsports. The turbo is in perfect condition, no shaft play, no leaking, etc. The kit has never been overboosted; in fact, it only saw a maximum of 5 lbs. of boost and it still made 218.84 whp and 156.47 ft. lbs. torque!
The only part of the entire kit that has a flaw is the downpipe. You can see in one of the photos below there is an indention on the bottom side from bumps in the road (this is pretty typical with used downpipes, header, etc.). It's not really that bad though, the flow is not restricted. Buyer is responsible for installation and tuning. Please get this installed professionally and tuned before you ever drive it, otherwise you could blow your motor! Also be very careful with the e-Manage and pc data cable, you can fry your ECU if you don't know what you are doing. Buyer assumes all responsibility. No Returns.
Old Apr 23, 2009 | 08:43 AM
WhiteSlips's Avatar
Default Re: ***Greddy Kit for B16, RC Injectors, Charge Piping, Apexi BOV, E-Manage, Gauges**
Bizump
Old Apr 23, 2009 | 04:36 PM
WhiteSlips's Avatar
Bump
Old Apr 24, 2009 | 04:36 AM
WhiteSlips's Avatar
Bump!
Old Apr 25, 2009 | 07:30 AM
WhiteSlips's Avatar
Bump!
Old Apr 25, 2009 | 06:59 PM
WhiteSlips's Avatar
Bump
Old Apr 27, 2009 | 06:05 PM
WhiteSlips's Avatar
Bizzump!
Old Apr 29, 2009 | 06:59 AM
WhiteSlips's Avatar
Bump
Old Apr 30, 2009 | 10:56 AM
WhiteSlips's Avatar
To the top!!!
Old Apr 30, 2009 | 12:55 PM
vsmftw98's Avatar
how much for just the 18g and elbow?
Old May 2, 2009 | 05:19 PM
WhiteSlips's Avatar
Read the red letters under where the turbo kit is listed....
Old May 2, 2009 | 11:44 PM
92hatch!'s Avatar
bump! for a fellow hatch owner and friend
Old May 10, 2009 | 02:08 PM
WhiteSlips's Avatar
B U M P
Old May 19, 2009 | 05:11 PM
WhiteSlips's Avatar
To the top
Old May 20, 2009 | 08:53 AM
WhiteSlips's Avatar
BUMP
Old May 28, 2009 | 07:04 AM
WhiteSlips's Avatar
To the top!
Old May 28, 2009 | 12:29 PM
WhiteSlips's Avatar
BBBBBBBBBBBBIIIIIIIIIIIIIIIIZZZZZZUUUUUMMMMMPPPPPP PP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 29, 2009 | 08:20 PM
WhiteSlips's Avatar
BUMP!!!!!!!
Old Jun 3, 2009 | 07:15 AM
WhiteSlips's Avatar
PUMP
Old Jun 4, 2009 | 10:53 AM
rdssk8rcs1's Avatar
still have the 18g turbo very interested
Old Jun 11, 2009 | 11:21 AM
WhiteSlips's Avatar
Do you want the whole kit or just the turbo? My friend does not want to part the kit if at all possible. Shoot me a PM instead of replying on the thread. Thanks.
Old Jun 12, 2009 | 04:48 AM
WhiteSlips's Avatar
BUMP
Old Jun 14, 2009 | 02:34 PM
American.Graffiti's Avatar
Bump for you!
Old Jun 20, 2009 | 04:38 PM
WhiteSlips's Avatar
Bump, stuff still up for grabs.
Old Jun 23, 2009 | 02:13 AM
imjustakid's Avatar
still have the injectors?? and where you located
VTcivicHB
Texas -OK -LA (Sales)
17
Aug 7, 2014 04:36 AM
k20z3boost
Apr 20, 2010 04:24 PM
WhiteSlips
Apr 16, 2009 09:12 AM
DeadLock23
Northeast (Sales)
13
Feb 14, 2006 05:14 PM
_jester_
Aug 26, 2003 06:08 PM
