Ls Swap HeLP !!!
Old Apr 22, 2009 | 10:05 PM
DnG8787's Avatar
Default Ls Swap HeLP !!!
I been working on my Ls swap on my ef civic the swap is done all I have to do pop the axels in on put the tires on that’s about it .. BUT the wiring harness is a problem … cuz my ef was a duel point injection and the Ls is different .. The plug that connects to the fuel rail to the ecu is different …. Is there a fast way to take care of this ????
Old Apr 22, 2009 | 11:06 PM
Redline130's Avatar
Default Re: Ls Swap HeLP !!!
You will have to convert your existing wiring harness to a MPFI harness. Do a search under "MPFI swap" or "MPFI conversion".
Old Apr 22, 2009 | 11:16 PM
D16SiHatch's Avatar
yea i dunno doing so particularly fast... but if you want it to run at all you will need to convert from dpfi to mpfi.
http://hondaswap.com/swap-articles/d...writeup-49557/
boostedefhatch
Oct 13, 2012 07:09 PM
ryanevansoh
Oct 5, 2008 05:47 PM
drowzysleeper
Aug 25, 2005 02:49 PM
