timing off?
ok so i finaly got my hatch running, and was noticing (and so have my friends) that it doesn't make any torque or power below 3krpms, then it takes off like a rocket. starts up great every time, doesn't smoke or over heat. ignition timing has only been done by ear, due to the motor not currently having a timing cover on it at all.
here's some specs if it helps:
88 std hatch 4spd manual, mpfi swapped. pm6 ecu, injen intake pipe with a specter filter, ls tb on a d16z6 intake manifold, d15b1 block and head a b7 cam, auto z6 4-2-1 header to a 2.5" ebay test pipe to a stock sir exhaust (which is 2.25" piping all the way back i believe).
of course i will check the timing tomorrow after school, but thought i'd post up on here first to get some ideas.
also... it is throwing a code nine, i havn't been able to trace down why yet (unless it's because it's not been properly timed) because everything is within specs.
jakscivic
11
May 1, 2006 08:36 PM
Shaguar47
Mar 13, 2005 04:25 PM
